Old 11-15-2015, 01:33 PM
snakehenry snakehenry is offline
Default Error 2753. The File 'pro tools user setup.exe' is not marked for installation.
I'm trying to install Pro Tools 11.3.2 on my windows PC, it's an 8 core machine with the i7-4790S CPU running a 64 bit version of Windows 8.1. I've tried loading from the disks and loading from the DL version to no avail, I've searched the APAC and Knowledge Base and found a few references regarding other versions or Win 7 , pt 12 ETC.
The error is as follows:
I've turned off Anti Virus and my Firewall to try another install but, the same error comes up.
Avid account is activated as well as the iLok, all licenses are transferred to the iLok. Must be something simple. No doubt I've fat-fingered something, again?
Welcome any thoughts out there,
Regards
snake
Old 11-18-2015, 08:46 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Error 2753. The File 'pro tools user setup.exe' is not marked for installation.
Try this
http://www.ehow.com/how_5047270_fix-internal-error.html
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-20-2015, 09:11 AM
Many thanks, Benoni
I have the Perpetual License for PT 11. I'm now able to install 10.3 and everything is working properly. I only had the install issue with Pro Tools. I should be able to download the upgrades and plugins without a problem. Little bit of a learning curve with the new versions of PT but, worth the effort. Thanks again, I'm happy to be on this Forum!
Old 08-20-2016, 12:51 PM
thehumanscience thehumanscience is offline
I'm getting this same error and the link in this thread did not help. I even ran the the protoolsusersetup.exe as an Administrator and it still failed to intall 11.3.2 on my Windows 8.1 machine. Any other ideas?
Old 09-16-2017, 06:34 AM
Aussie169 Aussie169 is offline
Did anyone sort this out? Getting same error Installing 11.3 on Win7
Above link didn't help.
About to throw the computer out the window
Windows 10 issue. Error 2753. Martin11 Pro Tools 11 14 11-29-2015 08:50 PM
Error 2753 when installing PT11, on a Win7 which already has PT12 Rockman413 Pro Tools 12 2 05-29-2015 07:18 PM
User.Kad (KAD File 174) Error Message justus1900 Pro Tools 11 3 11-30-2013 12:30 PM
PT8 installation error >SetupNew\setup.cpp grandmochismo General Discussion 8 01-08-2013 07:30 PM
PT10 Error opening installation log file elovaarar Pro Tools HDX & HD Native Systems (Win) 1 11-19-2012 06:42 PM
