DAE error -9073
I'm getting this error message so often I can't work:
"DAE can't get enough audio from the drive(s) fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load. (-9073)" I started getting blue screens over a month ago and I thought it was PT, but it turned out to be some kind of hardware problem. Long story short, they ended up replacing my hd, mobo, cpu, and power supply, all under warranty, so I assume everything was at least as good as what I started with. I got 8.0.4 installed and running, and it was working for a little while, but I just started getting this DAE error -9073. I never got it before I had all the hardware replaced; is it possible they gave me a bad harddrive or a much slower cpu? I'm trying to figure out if this is a hardware issue (which would mean I got f'ed by the Geek squad, Gateway, or both) or a software issue (PT only). Any insight is appreciated! (I'm fairly new to PT and mainly do simple DIY bedroom recording) |
Re: DAE error -9073
are u recording to u system drive..if so, that's properly your problem
"IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive.
Brian Uller Denmark |
Re: DAE error -9073
Re: DAE error -9073
It's a desktop actually, and yes it looks like the hd is 5400 rpm. What I'm confused about is that before I had all the stuff replaced, my PT was running like a champ and I never had this issue (I was recording well over 10 tracks of both imported stereo tracks and recorded tracks). Do you think if I just installed a second hd just for recording and made sure it was 7200rpm this problem would go away? The only reason I'm skeptical of this solution is that it was running great before on (supposedly) the same hardware setup. Could it be related to my installation? Would a re-install possible solve it?
Re: DAE error -9073
Re: DAE error -9073
I put a new 1 TERRAbyte 7200 rpm internal HDD and got a 2 TERRAbyte external 7200 rpm HDD got a 939 cpu ; the internal and external are both new and I am getting a 9073, XP is my OS
Re: DAE error -9073
If I used Acronis to clone my system drive in order to put in on a new WD Caviar Black, would I still need to re-install everything (windows, PT, etc) or would they be on the image?
Re: DAE error -9073
B1gun, please start your own thread and include a Sandra report(or nobody can really help). As to Acronis, if you use it to clone your system drive to a new drive, you should not need to re-install anything. There are a few plugins that lose their authorization(IK Multimedia for one). So you need to re-authorize those with the proper code. Usually a simple email to IK tech support will net you a new code.(just explain that you have re-installed the plugins on a new hard drive).
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error 9073 | djobar | Storage Subsystems | 0 | 12-06-2007 08:06 AM |
-9073 error | darrylectomy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-28-2007 07:25 PM |
error -9073 | standish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2007 05:33 PM |
adat loopback error#4 and error 9073 | uri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-22-2003 11:19 AM |
