OMF Import from Logic = White Noise!
So I just did my first OMF export of a song from Logic 9.1.3 and imported it to PT9 only to find all the regions now consist of white noise. If I could get this working it would be great, Any ideas? |
Re: OMF Import from Logic = White Noise!
On the whole I've had better results from AAF Logic-PT transfers so maybe you should give that a go first.
If for some reason you really need the OMF - first thing is to double check your Logic export settings - make sure you've got 'include audio' and 'convert interleaved' checked, that you're using OMF v2, and make sure the bit depth and sample rates are the same as the PT session you're importing to. When you import to PT, I would strongly recommend using 'copy from source media' as I've found referencing embedded OMF audio can lead to some pretty screwy behaviour. |
Using AAF worked for me. Can someone tell me what the diff is between OMF and AAF?
Also: Is there a 'catch-all' or 'macro' way of exporting/importing whole projects that include midi and audio? ie - not copying indivicual midi regions, but importing the whole session; region positions included. The AAF just reads and lines up the audio. And I expect it's asking way too much to include channel plugins!? One day? Thanks Ben |
I had the same Problem with OMF, just white noise, also from Logic. But AAF worked fine.
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
FCP OMF import into PT9 is white noise | EverettMarshall | macOS | 1 | 04-13-2011 12:55 PM |
White Noise on PT 8.1 mac session import | application4 | Pro Tools TDM Systems (Win) | 2 | 12-06-2010 05:10 PM |
White Noise when "recording" into Logic via MBox | funkpolbrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 12-17-2006 04:33 PM |
Logic and HD white noise. Please help! | ozinga | Pro Tools TDM Systems (Mac) | 5 | 07-21-2003 04:55 PM |
import audio and only get white noise | Kris75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-20-2002 04:21 PM |
