Old 09-29-2010, 02:20 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Problem with PT install
Originally Posted by Vmann View Post
Me again...just thought I'd mention that that I unistalled PT from my P4 account the problems above. Decided to try a reinstall since it'll be a while before I get my new computer system.
I'd forgotten that I had installed a high speed USB hub on the P4. Of course originally I hooked up the 11r into the USB 1 port which I believe was the part of the problem originally. But when I switched to high speed connection, voila!! PT installed successfully! Still a little slow on start up but manageable. Had time to watch about half the training video and I've got to say I'M STOKED.
Time willing I'm going try a recording and hopefully get it up here. All this to say that a P4 might do in a pinch....thx
Jim
If the P4 works for now for what you need, then great.
If you still want to build a PC, I would check into a i7 core. the i7 930 would be fine. i7's use a X58 chipset motherboard. I suggest the i7 over the other Core Intel's (i3 i5) because the i7 is a 1366 socket, and you would have the ability to upgrade from the Quad core i7, to the Six core or 8 core i7 later on. The i7's are hyperthreaded and each core can process 2 threads, so your PC will read the Quad i7 as an 8 core, the 6 core i7 as a 12 core, and the 8 core i7 as a 16 core
Most of the i5's are hyperthreaded Dual cores, a couple are NON hyperthreaded Quads.
The i3's are hyperthreaded dual cores with out turbo boost IIRC.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Install Problem lskboy1 Windows 2 07-11-2012 11:48 AM
can't install--mac problem or pro tools problem? tutti_frutti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-10-2011 02:41 PM
ELS Vocoder plugin problem and fresh Windows 7 install problem Thorpey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2011 05:03 AM
Will LE install cause problem with HD install? abbyin3d Pro Tools TDM Systems (Mac) 2 10-12-2005 07:46 AM
install problem Morgan52 Digidesign Hardware & Software 3 07-11-2001 11:27 AM
