Old 09-27-2010, 09:13 PM
paulsfinney paulsfinney is offline
Default Tape Delay wow and flutter
The wow setting on the tape delay on my Eleven Rack keeps going back to 1.78%-1.80% no matter where I set it. Is there another setting which can be turned off to keep it from changing back to 1.78?
Old 09-28-2010, 04:21 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Default Re: Tape Delay wow and flutter
A little more info would help, if you don't mind.
How is it switching back to 1.78-1.80? I mean, if you manually adjust the control to something else, does it suddenly jump back to 1.78? Or does it jump back when you leave the edit page and return to it? Or is it possible that you forgot to save the Rig?
Are you running Firmware 1.0.3?
Other stuff: Are you running Pro Tools (and if so, what PT version and computer/OS) or standalone? Are you using a MIDI controller or other expression pedal to control Wow? Do you have Sync engaged (not that that should matter in this case).
This is the first I've heard of an issue like this...hopefully we can help you nail down what's happening.
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Tape Emulation - Using Tape Delay to shape tone derker Eleven Rack 15 04-13-2011 09:10 AM
Reel Tape Delay. barismanco123 General Discussion 0 02-20-2009 07:45 AM
Tape delay plugin for LE? psychoth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-20-2005 03:35 AM
tape delay sound? jonny munka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-27-2003 10:06 AM
Tape-delay simulation radiofreak Tips & Tricks 3 06-28-2000 09:00 PM
