Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-03-2010, 06:33 AM
jolita jolita is offline
Question drum pattern to pt instead of just midi notes???
im trying to record drum pattern to pt instrumental track but all I get is midi notes how can i record actual drum beat that i have in my keyboard??? it should be possible? thanks. I have yamaha mm8.
Old 01-03-2010, 01:02 PM
Alan Z Alan Z is offline
Default Re: drum pattern to pt instead of just midi notes???
If you want to record the analog wave form of the drum pattern then use the audio outputs of your MM8 into a stereo audio track. Instrument tracks are a hybrid combination of an audio track and a MIDI track but the information they record are strictly MIDI notes.
PT 12.8.2
macOS Sierra 10.12.6
iMac (27-inch, Late 2012)
3.4 GHz Intel Core i7
16 GB 1600 MHz DDR3
Interface Focusrite Saffire PRO 24
Old 01-04-2010, 11:39 AM
Hey, I figured that out, but the fact is that I have this cable from MM8 output (orange and grey cables) plugged into mbox 2, but still when I record onto instr track I can record only midi. what I am doing wrong?
Old 01-04-2010, 11:41 AM
maxpidgee maxpidgee is offline
you cant record audio to an instrument track only midi info, you need to record to an audio track...
www.myspace.com/maxpidge
Midi drum editing and colored notes? TheBaron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-21-2010 12:50 PM
Please HELP - need to reassign midi notes for drum track funeral MIDI 0 02-05-2008 07:15 AM
Remapping Incoming MIDI Drum Notes funkhaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2006 07:13 PM
midi drum pattern library ? tantejo Tips & Tricks 4 01-10-2006 05:47 AM
Ticking noise after midi drum notes??? Gulliver MIDI 3 02-19-2001 08:46 PM
