FX Automation
I want to add an FX just at the tail end of a vocal phrase and I'm trying to determine the best/most efficient way to go about it.
If I put the FX on an AUX channel and create a send to that AUX, I noticed that there's no option to edit the volume like you can on an actual track, i.e. change the drop down menu from waveform to volume. Do I have to set the fader on the send to write, hit record and manipulate the fader during playback? However, if I'm only sending the one track I want the FX on, would using the volume on the AUX channel work the same way? I'm aware that I could also just highlight the section of the waveform I want the FX on and render it, but I'd like to leave myself some flexibility incase I need to change some of the settings as I progress in the mix. On a side note, are all time based FX's, like delay and reverb usually inserted into the mix via an FX send? What's the reason for this? Is it done to save CPU usage? Like if you're using the same FX settings on multiple tracks? Or are there other reasons besides that which make the FX's more effective via the send. I am aware of this method being used with FX of all types for parallel processing. Thanks, Adam |
FX Automation
Automate the send not the aux return channel.
The same place you choose volume, pan etc. on your audio track for automation will also have one for the send you've just added. Sent from my iPhone using Tapatalk |
Re: FX Automation
The insert created in the send column has one of those volume lines you can manipulate? I'm not looking at it at the moment, but I thought that it was just limited to the fader.
Re: FX Automation
Yes. It has its own automation lane.
Any parameter that can be automated will have its own lane including plugin parameters. You should have a read of the manual. Sent from my iPhone using Tapatalk |
Re: FX Automation
Haha. Tell me about it; manual's are like my kryptonite. I need to suck it up and start reading all of 'em, PT, plugins....
Re: FX Automation
Mixing a wet signal with a dry one always sounds better IMHO. Using time based FX on separate tracks can start to sound too 'muddied', especially Reverb. Having everything going through the same settings sounds more natural.....but of course as usual there are some exceptions to the rule.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
difference between MIDI automation and Audio automation on Instrument Track? | mariam | Getting Started | 5 | 04-28-2016 03:55 PM |
Import automation plug-in automation from an outside source? | idrejected | Post - Surround - Video | 0 | 07-06-2015 02:56 PM |
Convert MIDI automation to audio automation | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2010 03:28 PM |
automation issues (re-writing automation when it shouldn't) | revere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-13-2008 02:41 PM |
Automation Quirk...I didn't Write any Automation!! | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-20-2005 10:34 AM |
