Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-08-2008, 07:55 AM
Logic Pro Logic Pro is offline
Default Anyway to get pt to work with mac's aggregated device?
hi
i have a ozone with m-powered pt, i take the stereo out of the ozone via 1/4 to the ins of my duet, its very noizy, i get this fizz, so i like to ask if there is a way to output pt via apple aggregated device?
Old 11-10-2008, 10:08 AM
Default Re: Anyway to get pt to work with mac's aggregated device?
anyone at all?
Old 11-10-2008, 03:16 PM
DigiTechSupt's Avatar
No, there is not.
The noise you're getting is most likely a ground loop - have you looked into that?
If you can give us an idea of how everything is connected, we may be able to help. BE SPECIFIC right down to where things are plugged into for power...
Avid Audio Tech Support
Support FAQ
Old 11-10-2008, 05:59 PM
hi
Both the Ozone and Duet are connected normally to my Macbook pro 17, running Leopard,
However, i like to have the DUET be my main interface to my dynaudio BM6a monitors, and so i connected the stereo 1/4 outs of the Ozone to the 1/4 un balanced ins of the DUET.
I know that the stereo outs of any device are amplified and will have to be turned down very low to avoid distortion, but this is the only way i can monitor the Ozone through the DUET, but the high pitch fizz noise is annoying, i aint recording anything from the Ozone to the Duet but the fizz is pretty loud.
Can you suggest a better way to monitor the ozone?
Midi won't work unless I have a USB device bryced87 macOS 18 12-13-2013 06:26 AM
What -does- work as an aggregate device? Lorddiagram macOS 18 02-29-2012 07:07 PM
Usb Device Doesn't work gonzogtrman macOS 0 06-24-2011 08:46 PM
I installed another device & now command 8 no work SpencerC ProControl, Control|24, Command|8 0 10-01-2006 04:11 PM
Is 6.9.2 avaliable for "Aggregated Device"-Feature Zettt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-02-2005 01:52 AM
