Old 04-09-2021, 01:16 AM
metalindian's Avatar
metalindian metalindian is offline
Default Avid Link doesn't work
Hi all,
since a few weeks, since Avid released 2021.3, my "Avid Link" application doesn't work. I try to login but I get the error:
"Login Failed. Please check your username and password, then try again. Error #401".
If I enter an incorrect password consciously I get the Error:
"Login Failed. Please check your username and password, then try again. Error #400", so this means that the application recognizes my password.
Username and password are correct, if I try to Login via Avid website, I Login with no problems.
My Big Sur Installation was clean. I wiped out my hard disk, and then I reinstall Big Sur and then Pro Tools 2021.3.
Any advice?
Thanks in advance
Old 04-09-2021, 04:36 AM
Default Re: Avid Link doesn't work
Most people uninstall Avid Link because it doesn't work right - suggest you do the same.
Jack
QAPLA!
Old 04-09-2021, 10:41 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Great Advice.
Quit it, remove it, uninstall it. Think of all the time you can save dealing with Avid Link and, instead, be creative and make/produce music.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 04-09-2021, 11:47 AM
arche3's Avatar
arche3 arche3 is offline
I'm not even sure what it does.
Sent from my SM-G986U using Tapatalk
Old 04-09-2021, 12:02 PM
Here is a screenshot of the diagram where I show how "brilliantly" Avid Link is integrated with the other commands in Pro Tools.
Sorry for the low-res image quality. It is reduced by the forum engine
Edgar Rothermich
Old 04-09-2021, 02:28 PM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by metalindian View Post
...Any advice?
Thanks in advance
Greetings. I'm switching between 2 accounts here and both log in successfully. Have you tried Clear Cache Files in Preferences?
linkedin
Old 04-09-2021, 03:51 PM
Hi jeffro! Yes, I try to without success.
Further informations:
If I try to login From my Mac or Pc I get error 401.
If I try to login with Avid link App on my iPhone I login succesfully.
Inviato dal mio iPhone utilizzando Tapatalk
Old 04-09-2021, 06:23 PM
Never used Avid Link; if it runs through a browser maybe the op is behind a firewall or running script blockers?
Jack
QAPLA!
Old 04-10-2021, 03:44 AM
[SOLVED]
I Uninstalled Avid Link 21.2.1 version, and then I reinstalled the 20.6.0 version and.... BOOM, I logged in without problem
Old 04-10-2021, 08:04 AM
[SOLVED]
You should have stopped after uninstalling. Avid Link is awful.
Obsidian Dragon
Mac Studio M1Max - 64GB
So how does Avid Link and Collaboration work? JCBigler General Discussion 2 10-20-2020 03:47 PM
Link Mix/Edit Group Enables doesn't work audiocontrol Pro Tools 12 3 06-15-2016 09:22 PM
Link on avid site doesn't work.. Carlos Juvandes General Discussion 4 03-29-2012 10:12 PM
Exporting OMF embedded from LE to Avid doesn't work tomjoyce Post - Surround - Video 0 12-19-2007 05:42 AM
DaBasstardz midi click setup.. link doesn't work. Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-06-2004 10:34 AM
