Exact steps to using MC Mix with Quick Controls in Cubase
Hi all -
I've been on a mission to get my MC Mix and/or MC Control to generate continuous controller data in Cubase. From what I've read on the internetz, Cubase is the only DAW that will do this, and you do so by configuring some faders on the box as Quick Controls. Once that's done, you can then assign the quick controls to generate whatever CC you specify on a per-track basis. Makes sense. However, when I go to the device setup Track Control, put it in Learn mode, select a quick control slot, and wiggle the fader to configure that slot to that fader, nothing happens. I don't see the MIDI data change in that window to reflect that it saw the fader. And the faders continue to function as volume faders, not Quick Control faders. I'm running Cubase 8.5.30, on a Mac Pro tower running OS 10.11.x. I've established that the MC units have the latest firmware, and have installed the Eucon Driver 3.6. Everything else is functioning normally - the MC Mix and Artist see the Cubase track names, they operate correctly as volume faders, and so forth. I found a snippet online saying to hold down the EQ button until it blinks, and the faders will then be able to send CC data. I tried every permutation of this I could, and no joy. If anyone out there reading this has successfully mapped their MC Mix or MC Artist faders to Quick Controls in Cubase, would you be so kind as to lay out the exact steps you took to make it work? The number of hours I've already burned trying to get my MC series to generate continuous controller data has been silly. Many thanks in advance. |
Re: Exact steps to using MC Mix with Quick Controls in Cubase
i don't think it's possible because the MC mix talks directly to eucon only in a proprietary way. there's no CC data
Is there a quick way to pare down clips to exact length of waveforms [solved] | SigFriedChicken | Pro Tools 12 | 2 | 03-13-2017 08:53 AM |
assigning Quick Control in Cubase on Avid S3 | vudoo | Avid S1, S3, Dock and Control App | 1 | 08-08-2015 10:05 AM |
Eucon Command for Quick Controls on Nuendo 7 wont work. | KeyplayerG | Artist Series | 2 | 07-11-2015 08:54 AM |
How to have Quick controls on Mc mix from cubase 6 ? | entoine | Artist Series | 2 | 02-23-2011 02:13 PM |
MAC controls PC , PC controls MAC, wireless crazy stuff....you got to have it... | lucian | Tips & Tricks | 7 | 12-13-2000 11:20 AM |
