Old 11-17-2016, 03:40 AM
cygnal cygnal is offline
Default Fast Track Info
Win 7 64-bit @ CORE(tm)2 Duo
M-Audio Fast Track
Q1. Is it Fast Track USB, or Fast Track USB 2nd Gen? There are
two driver links with the same version number
Q2. During installation, doesn't pop-up the "Install this driver". Is it because I set-up trust for M-Audio credentials?
Q3. Firmware shows 0.3.0 for 6.1.2 driver, is this correct?
Q4. In Ableton Live, when multi-core support is on, massive dropouts on any GUI actions, such as scrolling withing the mixer. That is unnacceptable, and I believe it's due to the driver, because I had Transit USB before, and everything worked fine.
phasө is a bitch
bµɐƨө !ƨ ɐ p!ʇⅽµ
Old 11-18-2016, 01:43 PM
Default Re: Fast Track Info
-BUMP-
phasө is a bitch
bµɐƨө !ƨ ɐ p!ʇⅽµ
Old 11-19-2016, 01:54 PM
JoelG's Avatar
JoelG JoelG is offline
Which one do you have:
First gen: http://medias.audiofanzine.com/image...ack-611274.jpg
MKII: http://medias.audiofanzine.com/image...ack-632220.jpg
If you select to trust M-Audio, I don't think it will prompt when you install the driver. I'm asuming you mean the pop up similar to this: http://www.davidegrayson.com/signing...n7_maestro.png
I'm not sure what the current fimrware is, and it will depend on which device you have. Also, I don't use Ableton, you might get better answers for that specific problem from their forum: https://forum.ableton.com/
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 11-21-2016, 08:04 AM
Joel
Spot on for the answer. Mine is a 2nd Gen. Hope you understand the confusion.
And, yes, that was the dialog I had in mind.
Now for the big Q: Does it work with Pro Tools First?
There are drivers on the Avid website, under Legacy category. Pro Tools First complains driver is not present (6117, even though installed, that's why I was worried about the prompt).
Since Ableton recognizes it as ASIO subsystem, what is wrong in Pro Tools First?
phasө is a bitch
bµɐƨө !ƨ ɐ p!ʇⅽµ
Old 11-21-2016, 08:47 AM
JoelG's Avatar
Try pressing the N key when starting Pro Tools and make sure your Fast Track MKII is selected as the interface. http://avid.force.com/pkb/articles/e...t-FAQ#AAE-6117
Joel
Jam Space:
Home:
Rig:
Sound is playing too fast with M-Audio Fast Track Pro wodkin FireWire & USB Audio Interfaces (Win) 0 02-06-2015 09:42 AM
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 03:55 PM
Leaked info about new Avid Fast Track products nst7 Pro Tools 9 1 08-09-2011 11:52 PM
track confusion in fast track ultra interface deck Pro Tools M-Powered (Win) 0 02-24-2010 10:17 AM
Error - Info not getting to system fast enough Earfatigue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-16-2004 09:17 AM
