Old 10-06-2022, 12:00 AM
zavid zavid is offline
Default Apple M series Cpu better than Pro Tools HDX-HD Card ?
As the title ,
for talk about differences at the final mixdown bounce
made with Apple M series cpu Mac and Pro Tools HDX-HD cards system
can the Apple M series cpu really do better than Pro Tools HDX-HD cards system ?
cheers.
Old 10-06-2022, 12:11 AM
Southsidemusic's Avatar
Default Re: Apple M series Cpu better than Pro Tools HDX-HD Card ?
HDX cards are mostly used for tracking at near zero latency and make the CPU work less with higher plugin usesage and higher track count but don’t do that big difference when mixing down and boucing music if you don’t have massive sessions and score film etc
A M2 Mac or M1 Mac studio will do tracking very well and HDX systems like our HDX3 we use for tracking and same with our Carbon interfaces and HDX3 for some offload when those rare occasions we use any plugins that are DSP based (not counti g Melodyne S5 and Tools like that)
And since we use 99% high end outboards for that compression and eq’ing and saturation jobs in a song we might use 10-20% of the power of the HDX so absolutely no need for a hdx card/cards for mixing as a good spec Mac M will do the job even at high track counts IMHO of course :)
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-06-2022, 12:12 AM
JFreak's Avatar
JFreak JFreak is online now
No difference in sound. AAX plugin code is identical in DSP/native. Only difference is, not all native plugins can live in memory constrained DSP environment.
Janne
Old 10-06-2022, 12:17 AM
JFreak's Avatar
This.
And may I add that near zero latency is only really achieved without pluigins. Every DSP plugin instantiated makes the automatic delay compensation move signals accordingly, and using native plugins makes it even worse than native-only systems (with no DSP latency).
In math language "DSP+native" > "native". Same held true with discontinued TDM systems, it is not an HDX thing.
Janne
Old 10-06-2022, 02:41 AM
much thanks for post ,
then if only DAW Cpu and no HDX-HD cards:
really no progressive "Audio Data Compression/Cut"
parallel to the increase number of plug ins and track activated ?
.....since we use 99% high end outboards for that compression and eq’ing and saturation jobs in a song we might use 10-20% of the power of the HDX so absolutely no need for a hdx card/cards for mixing as a good spec Mac M will do the job even at high track counts IMHO of course :)
..the very nice old school ...
the outboards connected in insert to ADA converters ?
cheers
Old 10-06-2022, 02:46 AM
JFreak's Avatar
Track number depends on the tier of PT software license you have. Comparison here.
Janne
Has anyone tried NVIDIA 10 series card? jjsoundoc Pro Tools HDX & HD Native Systems (Mac) 6 08-25-2017 11:40 PM
FS: Magma Expansion Chassis 4 Slot Series w cable & PCI Host Card Phil Pelissier Buy & Sell 0 07-07-2015 10:09 AM
Apogee Rosetta 800 with x-series firewire card cacoong Pro Tools 11 12 01-09-2014 09:05 AM
Which Video Card for Apple G5? Basslab Post - Surround - Video 2 04-17-2008 12:51 PM
2 Apple 17'' LCD monitors on one AGP Card? Eduardo Apolonia Pro Tools TDM Systems (Mac) 14 10-16-2001 11:12 AM
