Tom Sholz\'s Rockman?
One of the best guitar albums i've ever heard is Boston's debut album. Amazing production. Therefore i'm looking to buy a Rockman Sustainor. i've found a couple on ebay and various shops. however i don't have the slightest idea what a good price for one is. Also i noticed there are a few different modules. Specifically xp100 and Sustainor. I believe the Sustainor is the one i want but i'm not familiar enough with any of them. I would prefer the half rack model as opposed to the soloist walkman version. I also don't want to buy the Guitar Ace or whatever the new company is. Any light you guys can shed on the subject would be greatly appreciated
www.myspace.com/onebadapplestudios |
Re: Tom Sholz\'s Rockman?
Andi |
HOLY COW!!!! They still make those Tom Sholz's walkman Rockmans? I had one about 15 years ago...I use to just clip it on my belt, plug in, put the head phones on and go CRAZY!!
Yeah, Amplitube>>> McDsp Compressor bank and a Les Paul should do the trick!! Or a wah at half pedal!!!!! [img]images/icons/smile.gif[/img] Ala Micheal Schenker-UFO-
METAL LABS |
I have a Les Paul (doesn't have the cool mighty mouse on it like his does though) and obvioulsy I have compressors, POD and all that other stuff, but I can't quite get what i'm looking for. I've messed around with Amplitube a bit and I get pretty close. So I figure if i tried all the alternatives might as well just go to the source.
The one to look for is the original ROCKMAN,,i think Sholtz sold it all to some one,,i'm not sure who,,and thats when all the variations came out,,the original was the bomb for that generic 80's sound,,it had a chourus and delay on it and was compressed to hell,,i went after one after reading that BILLY GIBBONS had used one on the ELIMINATER record,,it sounds cool as a DI and also if you run it through a power amp and out of a cab,,,i used mine so much it eventualy fell to pieces,,to the point that not even the magic GAFFA tape could save it,,but then the POD came along,,still it would be cool if LINE6 added a ROCKMAN model to its software,,
Originally posted by uiop:
The one to look for is the original ROCKMAN < Ditto...if you can find the original in good shape, get it. it sounds cool as a DI and also if you run it through a power amp and out of a cab,,, < Yep...I used mine live and in the studio. The distortion circuit was great for recording leads. i used mine so much it eventualy fell to pieces,, < Yeah...mine did too. I tried fixing it but I ended up buying a better tube amp rig. Bottomline...if I could find another original Rockman, in good shape, I would buy it in a hearbeat, and take better care of it [img]images/icons/smile.gif[/img] Good luck! |
The rack mount versions will give you all that the portables will and then some. I've used both extensively. The sustainor is a dual channel preamp with compression, noise gate and various levels of distortion. Part of the classic Boston sound is the chorus so you will need the chorus half rack as well. I have one in my rack but Im not home right now and cant recall the name of it. If you are interested in more info email me. I used one in a live setup successfully for years. The rack maount versions are also a little more roadworthy than the old portables (I wore out my portable too.) BUT I found after going to a POD just how noisy these thing are in the studio. With a good noise gate or some processing though its possible to get good recordings. Def Leppard also recorded the whole Hysteria album direct through Rockmans. In 1986 I paid just under $200 a piece for the half rack units. I will never part with mine just for nostalgic reasons. Later.
What's the difference between the distortion generatior and the sustainor?
Rockman X100 | Hamdi | General Discussion | 2 | 05-13-2011 11:23 AM |
rockman vst plug | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-11-2004 05:46 PM |
