Old 11-20-2020, 11:49 AM
lucienpalmer lucienpalmer is offline
Default Two HDX cards failed DigiTest
Hoping someone has insight into my test results. I have been having strange errors and crashes lately, so I ran Digitest on my 3 HDX cards.
Card 0 passed all tests. It's connected to an Avid MADI.
Cards 1 & 2 are connect3ed to a MTRX, and both failed the same tests...
Peripheral Loopback Connector 1 PRi - Failed unsupported Device
Peripheral Loopback Connector 2 Sec - Failed unsupported Device
SDI 0 PIOFloating Point Test - Failed
SDI 0 PIO TDM Loop Int B-A 192k - Failed
SDI 0 PIO TDM Loop Int B-A 96k - Failed
SDI 0 TDM PIO Loop Int B-A 192k - Failed
SDI 0 TDM PIO Loop Int B-A 96k - Failed
SDI 1 PIO Floating Point Test - Failed
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 11-20-2020, 11:52 AM
creativecontrol's Avatar
Default Re: Two HDX cards failed DigiTest
Your HDX cards are fine.
https://avid.secure.force.com/pkb/ar...ed-to-HDX-Card
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-20-2020, 12:20 PM
Woohoo!
Thanks, Jeff.
Old 02-23-2022, 11:44 AM
bobwish bobwish is offline
I just ran Digitest on 2 HDX cards connected to Two HD MADI I/Os, and got:
SDI 0 PIO Floating Point Test Failed
SDI 0 PIO Loop Single Chan Failed
SDI 0 PIO TDM Loop Int B-A Failed
SDI 0 PIO TDM Loop Int B-A 192K Failed
SDI 0 PIO TDM Loop Int B-A 96K Failed
SDI 0 TDM PIO Loop Int B-A Failed
SDI 0 TDM PIO Loop Int B-A 192K Failed
SDI 0 TDM PIO Loop Int B-A 96K Failed
SDI 1 PIO Floating Point Test Failed
on both cards.
Mac Pro 7,1
OS 10.15.7
Thanks
All of my cards failed the digitest bernisava Tips & Tricks 14 01-08-2011 08:51 PM
digitest failed pipolito Pro Tools TDM Systems (Mac) 2 03-28-2010 02:07 PM
Failed Digitest Buffstuffbuddha Tips & Tricks 4 05-07-2009 02:48 PM
Digitest. TDM Transmition failed on first 2 cards. SilkBasilar Pro Tools TDM Systems (Mac) 8 11-10-2006 06:01 AM
My cards Failed Digitest! Zep Dude Pro Tools TDM Systems (Mac) 1 03-07-2000 10:19 PM
