Old 11-05-2010, 06:00 PM
vudoo vudoo is offline
Default Is Procontrol/edit pack/ fader pack still supported
I did not see it on the PT 9 announcement. Is the Pro control still supported ?? Thanks
Old 11-05-2010, 06:11 PM
Cryos's Avatar
Cryos Cryos is offline
Default Re: Is Procontrol/edit pack/ fader pack still supported
were out of luck buddy, they want us to spring for the big ticket items or run a useless C24. I'm F--N'G pissed but not surprised. Avids got Big business mentality and shareholders to to answer to.
You and I are just not that important anymore.
I know for a fact that you can run a procontrol rig off an LE system simply by using the proper controller file, but I think those days are over.
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 11-05-2010, 07:32 PM
mgauvin mgauvin is offline
Have anyone tried to use the ProControl Contoller Profile file with PT9 ?
Old 11-05-2010, 07:36 PM
carlone carlone is offline
The pro control personality controller file is installed with PT9. That tells me that it should work. I guess those shareholders are just gonna have to be pissed :)
Old 11-06-2010, 06:31 AM
Cryos's Avatar
If this is the case, that be super cool, yet to be seen however, and how functional it will be.
Cheers
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 11-06-2010, 03:19 PM
psycho_monkey psycho_monkey is offline
The official reply has been "it should work" - ie they've done nothing to break it, remove the drivers etc - but you won't get tech support if it doesn't.
Old 11-06-2010, 09:01 PM
Cryos's Avatar
by any chance did you find out if the editpack was part of profile list?
On a side note, awhile back i upgraded my OS to Leopard on my G5, installed the last version of PT8 for PPC to find out that those of us running procontrols in surround and using the PC's monitor controls in surround mode, found the surround switch would toggle off all on it's own when instantiating plug-ins or automating them( digi actually acknowledged this as an official bug after they were capable of reproducing the same issue on their end) this bug essentially renders the PC surround monitor section useless, otherwise everything else seemed to work on the unit.
I went back to Tiger and 7.4 as there were myriad's of other issues.
All to be seen eh.
Cheers
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 11-06-2010, 09:15 PM
Shan's Avatar
Shan Shan is offline
"Supported", no. But it definitely works.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-06-2010, 09:19 PM
LukeHoward LukeHoward is offline
Yes, it is. EditPack, ProControl, and ProControl_M (matrix) are all there. There's a lot of jumping to conclusions going on here.
[IMG] code is Off
FS: Procontrol-Edit pack-Fader pack vudoo Buy & Sell 1 12-17-2013 02:48 PM
Procontrol with fader pack and edit pack The golfer Buy & Sell 2 11-05-2012 09:47 PM
HELP! Edit Pack thinks its a Fader Pack! digitaltoast ProControl, Control|24, Command|8 1 01-27-2012 04:48 AM
Looking for ProControl Fader Packs and Edit Pack BassBuddha ProControl, Control|24, Command|8 6 01-31-2011 02:47 PM
procontrol fader pack jerico ProControl, Control|24, Command|8 0 12-17-2008 09:08 AM
