with only 27% usage? protools 8.03 macpro dual quad 2.8 with 6GB ram
anyone the same problem? pete |
bump
What are your buffer settings?
What plugins are you using how many processors are you using and what protools interface. Maybe we can narrow it down. |
buffer setting 1024
lots of plugins... waves mercury, massey, digis,... 8 processors mbox pro |
Macs need at least 1 processor to dedicate to plugins so I would make urs set to only use 7 this has been proven to make macs work much more seamlessly with protools. Also see what ur rtas engine is set too. Try different values to change perormance. Hope it helps. Worked for me.
You are recording to a seperate disk as well right. Either a internal or an external FireWire. I'm pretty sure this can produce a CPU error as well somtimes. If an external FireWire make sure it is above the recommended disk speed for your protools version I beleive it's like 7200rpm don't quote me though.
sepparate internal drive 7200rpm yeah... - I'll try to put processors to 7 and see what happens
I messed around with buffer size already thx for the help! |
CPU OVERLOAD error 6101 HELP | hotel17 | Getting Started | 15 | 05-14-2016 02:24 PM |
error 6101 / 9128 CPU overload MAC PPC G5 | johnsongs74 | Tips & Tricks | 10 | 04-18-2011 05:03 PM |
CPU Overload 6101 error | FutureBC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2010 10:06 AM |
Error -6101 CPU overload macbookpro | Eddiex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-26-2010 03:02 PM |
(-6101) CPU Overload Error | CujoAC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 29 | 07-04-2008 12:20 PM |
