I'm curious if anyone with a little more experience than me can shed some light on Atmos file deliveries to Netflix, Apple, etc.
Some spec sheets state that Tracks 1-10 are reserved for beds, and 11-128 can be used for objects or beds. In my setup, the beds begin on channel 21 of DAPS, because I use the first 20 channels to return the mix and ReRenders back to PT for measurement. The first 20 channels are left blank when creating masters. Would my deliverables be accepted using this setup? Do beds need to start on Channel 1-10? Or, are we ok as long as beds are the first track in both the master output and the ADM WAV file? Thanks. |
Hi mman00,
You'll have to bear with me as I work with an RMU/DAMS, not DAPS, slightly different but the same in principle. Can you provide some info on how you are routing audio between tools and DAPS? Specifically if you are using an aggregate device, or Dolby Audio Bridge, or Send/Return plugs? Screenshot of you bus i/o would be helpful to. My first stab at this would just be to change the input config on DAPS. say you're sending your first bed from tools on channels 21-30, you can assign the inputs on DAPS to inputs 1-10, and then cascading from there. Hope that makes sense. Alex |
I am using the DAB as both this input and output device. I start my beds on channel 21 which opens the first 20 channels for monitoring and rerenders returns back to PT.
I'm wondering if anyone here can confirm if Netflix, Apple, etc. will accept delivery of Atmos files with beds starting on any channel, or do they have to start on 1-10? |
That's an interesting question....my technical guess is that it should not matter because the metadata file that is included with the Atmos deliverables details where beds/objects/etc are.
Whether in practice that data is actually used rather than assuming a specific channel layout, I do not know. |
Netflix deliverables. | TVPostSound | Post - Surround - Video | 11 | 05-16-2018 03:39 PM |
Deliverables question | amac733 | Post - Surround - Video | 2 | 01-22-2017 04:02 PM |
Deliverables Encoding | Nirvana5253 | Post - Surround - Video | 6 | 02-29-2016 12:06 PM |
FPS Deliverables | mellow1998 | Post - Surround - Video | 19 | 07-08-2008 01:32 PM |
deliverables question | anders | Post - Surround - Video | 3 | 12-12-2002 10:40 PM |
