Old 04-18-2010, 04:34 AM
peter99 peter99 is offline
Default error -6101 cpu overload
with only 27% usage? protools 8.03 macpro dual quad 2.8 with 6GB ram
anyone the same problem?
pete
Old 04-18-2010, 01:38 PM
Default Re: error -6101 cpu overload
bump
Old 04-18-2010, 02:59 PM
prestonrmail prestonrmail is offline
What are your buffer settings?
What plugins are you using
how many processors are you using
and what protools interface.
Maybe we can narrow it down.
Old 04-18-2010, 03:12 PM
buffer setting 1024
lots of plugins... waves mercury, massey, digis,...
8 processors
mbox pro
Old 04-18-2010, 03:24 PM
Macs need at least 1 processor to dedicate to plugins so I would make urs set to only use 7 this has been proven to make macs work much more seamlessly with protools. Also see what ur rtas engine is set too. Try different values to change perormance. Hope it helps. Worked for me.
Old 04-18-2010, 03:29 PM
You are recording to a seperate disk as well right. Either a internal or an external FireWire. I'm pretty sure this can produce a CPU error as well somtimes. If an external FireWire make sure it is above the recommended disk speed for your protools version I beleive it's like 7200rpm don't quote me though.
Old 04-19-2010, 03:28 AM
sepparate internal drive 7200rpm yeah... - I'll try to put processors to 7 and see what happens
I messed around with buffer size already
thx for the help!
CPU OVERLOAD error 6101 HELP hotel17 Getting Started 15 05-14-2016 02:24 PM
error 6101 / 9128 CPU overload MAC PPC G5 johnsongs74 Tips & Tricks 10 04-18-2011 05:03 PM
CPU Overload 6101 error FutureBC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2010 10:06 AM
Error -6101 CPU overload macbookpro Eddiex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-26-2010 03:02 PM
(-6101) CPU Overload Error CujoAC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 07-04-2008 12:20 PM
