  #31
Old 07-25-2019, 12:32 AM
Ben Wood Ben Wood is offline
Default Re: All lights flashing on my D-Command
citysoundman, could you link the Sager PSUs you ordered?
I would be useful to look at the specs to see if I can find one in the UK.
Many Thanks
  #32
Old 07-25-2019, 03:12 AM
citysoundman citysoundman is offline
Many Thanks
Sure thing https://power.sager.com/snp-z10b-3979628.html
it's also quoted earlier in this thread.
Bob Kirschner
Chief Engineer
Creative Media Design, NYC
http://cmdnyc.com
bob@cmdnyc.com
  #33
Old 07-25-2019, 03:24 AM
Thanks citysoundman but this is the 3.3V version. I was told I needed a 15v version for the Logic PSU.
I've had a look on Sagar and found this...
https://power.sager.com/snp-z108-3979624.html
I think each PSU has different voltages.
I'm assuming the LEDs is 3.3v, Fader is 12v and Logic is 15v?
Thanks
  #34
Old 07-25-2019, 03:32 AM
Thanks
I only looked into replacing my LED PSU. Sorry I don't have info about the others. Skynet USA does repair the LED PSU's and they might also repair the Logic PSU...not sure...but that might be an option for you.
Bob Kirschner
Chief Engineer
http://cmdnyc.com
bob@cmdnyc.com
  #35
Old 07-25-2019, 03:44 AM
Hi citysoundman
I bought it spare/repair, not powering on.
I opened it up to find the Logic PSU missing so I need a new one
Thanks
  #36
Old 07-25-2019, 03:53 AM
Hi citysoundman
Thanks
Oohh Ouch! Sorry to hear that. So Sager doesn't sell a model that meets the specs of the Logic PSU?
I guess you've tried to reach out to Avid already?
It's a longshot, but Skynet did manufacture the PSU's for Avid (the LED PSU for sure, not 100% certain about the others but I assume so) you could try them. Good luck!
Bob Kirschner
Chief Engineer
http://cmdnyc.com
bob@cmdnyc.com
  #37
Old 07-25-2019, 04:00 AM
The UK Sagar distributor doesn't stock the 15v PSUs.
I have got in contact with the approved AVID UK repair company.
I should get it sorted.. for £180
Thanks
  #38
Old 07-25-2019, 06:46 AM
Does anyone have any specs for the Logic PSU and pictures of how it connects?
Many Thanks
  #39
Old 07-30-2019, 08:09 PM
arche3's Avatar
arche3 arche3 is online now
Many Thanks
There is a d control maintenance manual online. It has all the info. But doesn't list part numbers. Just how to fix everything.
Sent from my SM-G975U using Tapatalk
  #40
Old 01-20-2020, 12:49 PM
Ken Skoglund Ken Skoglund is offline
Old thread, but my D-Command broke last week, and I was searching for info, found this, and it helped a lot. My issue was my main unit just died, some LEDs in the main monitor section were lit, but no buttons worked, and everything else was dead. (faders worked on power up).
Thanks to info here I could measure my PSU's and the LED PSU voltage was drifting from 0,3V-2,3V. Suspected the capacitors. I thought I try to fix it before ordering a new, because I'm in Sweden and any order from the US would take weeks. (it died in the middle of delivering a TV show). So I removed all big caps and the 4 bigger ones had clear signs of leaking, green electrolyte under them. Ordered new ones, the 2 big ones on the pict plus the 2 smaller ones under the heat sink. I could not fins 1200uF so I went with 1500uF. 2 big ones -easy to remove, 2 smaller - PITA. Soldered on both sides of the circuit board and one is under the heatsink (that had to be removed).
Anyways, with the new caps the PSU worked fine and I'm back in biz now, to the cost of about $10, a few 220V shocks in my arm and a lot of cussing :) Thought I share the experience if anyone wanna try it. Here is a pict with the values etc.
Mbox 3 Flashing lights drumzalicious FireWire and USB Audio Interfaces (Mac) 3 06-01-2014 02:23 AM
Flashing lights Mbox Sid0 FireWire and USB Audio Interfaces (Win) 11 04-23-2013 03:58 PM
flashing lights? stainless ICON & C|24 1 05-31-2006 02:49 PM
Flashing lights on 002, anyone else? Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-09-2003 09:46 PM
What's with the flashing lights? ngisedigid Pro Tools TDM Systems (Mac) 10 02-28-2002 01:06 AM
