Old 01-28-2012, 04:26 PM
TimNielsen TimNielsen is offline
Default HD Native Firmware Flash
As part of the upgrade to 10.0.1, I saw on Avid's website that I needed to flash the firmware of my HD Native card. So I downloaded the flash updator.
Just FYI, it's now been going almost FIVE HOURS, and it's 86% done, and that might only be one the first pass. Then it will probably try and verify.
Just FYI, to anyone else out there, there seems to be something VERY wrong with the firmware updator for the HD Native card at the moment.
Of course I can't quit for fear of it trashing my card and making it unusable.
But Avid, WTH is going on with this thing?
Old 01-28-2012, 11:08 PM
cmaynes's Avatar
cmaynes cmaynes is offline
Default Re: HD Native Firmware Flash
Tim, what OS and Mac are you using?- I know there were issues with 10.6.8 and the Harpertown Macs- you might try booting with a 10.6.7 startup disk to do the update if possible....
charles maynes
sound design and recording for film and media
818 618 0580
Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC.
Old 01-29-2012, 02:12 AM
danander11 danander11 is offline
Said he was using 10.7.2
I use the same and mine was finished in less than 5 minutes. I dunno.. The last time I bounced back up to ten on the old firmware updater it took hours.. The new updater worked like a champ for me.
I use an 8 core Clovertown with the card in slot 3.. Have you looked at where your card is installed? (glad it's working for you though).
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 01-29-2012, 07:13 AM
Carl Lie Carl Lie is offline
I had a problem with a firm ware update on the Native Card and moving it from slot 2 to slot 3 fixed it.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 01-29-2012, 08:45 AM
Yeah, I think that's the next step for me, to move the card out of slot 2. It seems for whatever reason people are noticing problems in slot two.
Old 01-29-2012, 01:59 PM
It has to do with the speed of the slot if I recall.
Here I am,
Hobo Shave!
Downgrade Native firmware 10 to 9? Hugh-H Pro Tools HDX & HD Native Systems (Mac) 2 04-12-2013 09:53 AM
Native Card Firmware Version ? SpongeBob Pro Tools HDX & HD Native Systems (Mac) 5 02-03-2012 03:25 PM
MIDI I/O Firmware flash? DetroitT MIDI 0 09-26-2011 08:52 AM
RESOLVED: I updated PT LE 8.0.1 to 8.0.5 AFTER the Eleven Firmware-Flash... _mat Eleven Rack 2 03-24-2011 11:53 AM
SSD..updated firmware, now light just flash, doesn't work!! HELP!! maxtraxstu Pro Tools TDM Systems (Mac) 6 01-18-2000 03:52 PM
