Protools 2018 and Surface Book 2 Audio Problem
I have almost 2 weeks daily trying to make sound the speakers of a
surface book 2 with pro tools 2018 and nothing. Someone tested in a surface book 2? If yes what was used to make work? I have a focusrite and works fine but when I travel I don’t carry the focus rite and sometimes to use for previews and fast things the speakers are fine. Before install the asio4all driver in playback configuration inside protools I saw only the low latency generic driver (when I’m not connected in the focusrite, of course). And after install the asio4all, I saw the asio4all playback device in protools, but no matter what output I select there (in asio4all), there is no sound. The default speakers of the surface book 2 are realtek, but no sound if selected in asio4all. I see the audio levels monitors move but zero audio. What could be the problem? |
Re: Protools 2018 and Surface Book 2 Audio Problem
What operating system? W10?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yes exactly. Windows 10 installed.
Please open the asio4all and verify your version and configuration. My asio4all (1.0.0.1 x64) has:
1. "All host application to take exclusive control......"(checked) 2. Under Device Name, "Realtek (High definition adio...." (checked) 2 channel 16 bit. Nothing else is checked and this works on my Surface Pro 5. |
http://tinypic.com/r/29qe33p/9 There are the advanced options but I don’t see the options you mention. Any idea? Thank you |
How would I connect the Roland TR-8S to 003 Work Surface (PT 2018.4.0), through USB2? | jamesleonard | General Discussion | 7 | 03-25-2020 03:19 PM |
Sierra and ProTools 2018.3, big clicks + audio loss | o-matic | Pro Tools 2018 | 12 | 06-07-2018 01:04 AM |
Pro Tools not starting on Surface Book | larszi | Getting Started | 3 | 04-08-2018 03:10 PM |
Does protools run on all Mac Book Pro? | kindred | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-28-2010 08:56 AM |
Red Book audio problem | dmaxj | General Discussion | 3 | 05-21-2003 08:56 PM |
