Recorded Audio from MIDI Instrument Placed Early on Timeline?
Windows 10 Home
Pro Tools 2019.10 EZdrummer 2 The recorded audio from MIDI Instrument plug-in is being placed early on the Timeline, what's going on? |
Re: Recorded Audio from MIDI Instrument Placed Early on Timeline?
Q: are you Quantizing on the way in ???
Did you Commit, Bounce or Record the audio tracks?
Given your 2 screenshots, it looks like you might have used an Output from the Instrument, routed to the Audio Tracks, and recorded in real-time. You also have Delay Compensation off. Try turning it on. That might have something to do with it? |
I see now the MIDI Offset settings in Events menu, and making changes there does seem to affect how the recorded audio is placed on the Timeline, but not yet clear from where to derive precise values... |
Send to your print tracks via internal bus’s. With ADC on.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Is the input from the plug-in not an internal bus?
Taylor4814, please report this ASAP to Avid Customer Support.
In short, I could say: Forget about doing MIDI with current Pro Tools versions, but that's not very helpful to you. These problems have been ongoing for quite a while now and Avid has proven incapable of solving them so far. To give you some more information related to what you may be experiencing: I have a similar/related case open with them since 10/15/2019: 03803594 MIDI is recorded early on timeline with ADC enabled The case's status is currently 'Research Pending' but you adding to it may stress the urgency of fixing these MIDI timing errors. Following of my cases reported starting 2016 were closed by Avid without ever being solved: 03089491 Problems with MIDI delay compensation, MIDI note-on messages and MIDI volume (11/24/2016) 03106387 Automatic delay compensation for external MIDI instruments not working while input-monitoring (12/16/2016) 03120087 Instrument Track Commit results in huge audio delay / Case Closed / Bug Logged/Known Defect (1/8/2017) 03802429 Automatic Delay Compensation broken when used with LLM and external MIDI instruments / Case Closed (10/13/2019) Following DUC threads are related, and may be worth a read (in no particular order, some of them deal with VIs, some with external MIDI instruments, but the timing problems are the same): http://duc.avid.com/showthread.php?t=351476 http://duc.avid.com/showthread.php?t=377147 http://duc.avid.com/showthread.php?t=387939 http://duc.avid.com/showthread.php?t=327520 http://duc.avid.com/showthread.php?t=387551 http://duc.avid.com/showthread.php?t=384719 http://duc.avid.com/showthread.php?t=355284 http://duc.avid.com/showthread.php?t=378631 http://duc.avid.com/showthread.php?t=400728 http://duc.avid.com/showthread.php?t=279955 http://duc.avid.com/showthread.php?t=400356 http://duc.avid.com/showthread.php?t=407114 http://duc.avid.com/showthread.php?t=386932 http://duc.avid.com/showthread.php?t=396670 http://duc.avid.com/showthread.php?t=350427 http://duc.avid.com/showthread.php?t=266853 http://duc.avid.com/showthread.php?t=404552 http://duc.avid.com/showthread.php?t=386299 http://duc.avid.com/showthread.php?t=363877 |
Wow, that looks like the mother lode, thanks very much for all the information.
So, what are people doing, just shifting their tracks by a certain sample offset? Do you have to approximate that? Because, even in my simple example, using Tab to Transient, I was getting different amounts for the length of the sample offset… |
Ok— for me, the issue is now effectively resolved...
The Global MIDI Offset field in my session had a value of -740. Not being familiar with this setting, I first assumed it was supposed to be there; and though I did initially try resetting it, I must not have done it correctly. With it now set to zero, in my instance, the audio appears to be recording properly on the Timeline, and sounds right. I do notice, when zoomed all the way in to the sample level, and with waveform vertical zoom way in, that what appears to be the start of the waveform looks maybe 9 or 10 samples delayed from the grid... but at normal zoom everything looks, and sounds right to me. |
MIDI being recorded early | rosindabow | Pro Tools 2018 | 3 | 10-15-2019 05:40 AM |
Latency bug - recorded audio 1ms early | RuLemer | Pro Tools 12 | 4 | 02-07-2018 01:30 PM |
Recorded audio placed 40ms too early | peteage | FireWire & USB Audio Interfaces (Win) | 3 | 09-11-2013 08:05 PM |
Recorded audio playing back too early | jonwade92 | macOS | 3 | 04-15-2013 01:01 PM |
Midi recorded early | allstaar | macOS | 2 | 05-09-2011 03:27 PM |
