Old 01-30-2019, 07:50 AM
LesPaulGtr LesPaulGtr is offline
Default Artist Mix Power Button
Hi All,
So, I picked up a second-hand Artist Mix and it has the following issues:
1. If you plug in the power supply, the unit automatically turns on without pressing the power button.
2. After the unit is on, pressing the power button does not turn the unit off, only seems to make it lose connection to EUCON.
3. All other aspects of the Artist Mix work perfectly fine.
Obviously something wrong with the power switching circuit, anyone know if it's an easy fix? Otherwise, I don't see it as a big deal to plug/un-plug or attach an inline switch every-time I want to use it. Is it safe to operate the unit that way?
Thanks!
Old 01-31-2019, 07:38 AM
EddieJones's Avatar
Default Re: Artist Mix Power Button
The power switch is actually a soft power switch so it might be OK.
Old 02-03-2019, 08:29 AM
KingTor KingTor is offline
I keep ours on a power strip and very rarely turn it off with the soft power button. I'd go with your workaround and wouldn't worry a bit about it.
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 11-08-2019, 12:25 AM
Dutchmountain Dutchmountain is offline
I had the same problem with the Artist Mix but solved it the following way...
1) Remove the backpanel ( 9 black Torq screws )
2) Lift of the Aluminum plate
3) Locate the inductor labeled L7 on the circuit-board close to the power connector.
4) re-solder the 4 legs of L7
That was all and after connecting it to the powersupply my Artist Mix was working again using the power button.
So there was definitely a bad soldering connection on the circuit board.
In other Posts on several forums some people reported that the L7 was damaged
In that case you have to replace it.
Hope this helps
Best regards Hans
Artist Mix, Artist Mc Control, Pro Tools, Cubase, Imac 27”
Old 10-26-2021, 01:36 PM
ferri ferri is offline
Similar issue here: I bought a used Artist Mix, worked fine for a couple weeks then it stopped communicating with Eucon.
It powers up when I plug it in but the power button has no effect, at the moment all I get is the blinking lights at startup then the avid logos
DHCP is fine
I guess I’m gonna try reflowing L7 next time I open it.
Is there a way to test if the component is damaged?
Danks
Old 10-26-2021, 02:18 PM
EddieJones's Avatar
If its getting to the Avid Logos its booted fine, its your network that could be the issue.
Old 10-27-2021, 01:48 AM
Thanks I’ll double check that
Can I SAFELY power up Artist Series units from a power rail? KeyplayerG Artist Series 3 07-10-2017 09:46 AM
Avid Artist Mix Stops Left Button On Mouse dondigital Artist Series 5 03-02-2015 08:50 AM
Artist Mix SEL button doesn't work mlemos Artist Series 7 05-03-2013 01:52 PM
Power Button on 002R btdvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-07-2005 11:06 PM
G4 usb Power Button ? TommyT Pro Tools TDM Systems (Mac) 1 01-02-2002 05:23 AM
