Old 07-29-2016, 09:50 PM
1m1 1m1 is offline
Default Can't enter ticks in 12.5.2
I just installed 12.5.2 and am experiencing something I've never seen before. When I try to enter a value in the Ticks field of the counter, it doesn't take. It just remains at 000.
Also, if I select the Bars in the counter and hit the "." (period) key, it will jump back and forth between the Bars and Beats, but never goes to the Ticks.
Is there some option that I need to change to make it work like normal?
Old 07-30-2016, 12:00 AM
1m1 1m1 is offline
Default Re: Can't enter ticks in 12.5.2
I did some poking around and I found that it has to do with hiding ticks and milliseconds in the big counter. If I hide ticks and milliseconds on the big counter, then I can't enter them from the keyboard. Ugh. I don't like that way of working. I use the big counter as a display for the musicians, but I like to be able to access ticks for myself. Has anyone else found a workaround for this?
Old 07-30-2016, 08:12 AM
john1192 john1192 is offline
i hear this .. and suggested that PT has more than one configurable Display ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Bug : Return/Enter Key working as Enter Key in PT HD12.5 Maverick and El Capitan AMIEL Pro Tools 12 0 05-17-2016 01:47 PM
viewing ticks mentonium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-21-2007 02:51 AM
Ticks vs. samples gastrocnemius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-31-2006 04:07 PM
Can't enter memory locations with "enter " key? bhooligan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2005 01:42 PM
Digital Ticks winter20 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-27-2002 12:37 AM
