Old 05-09-2019, 02:23 PM
KingTor KingTor is offline
Default software problem on Mac OS X.7 (Lion)
We (finally) replaced our hackintosh which was running old HD|Accel software, but still couldn't justify the expense of upgrading the hardware to be compatible with PT 11+, so we got a refurbished "cheese grater" Mac Pro, put in the PCIe cards, installed Mac OS Lion on one partition (so we can run PT 9 HD sometimes, which is what I'm doing right now). All is working very well, including all the plugins I need for print mastering, except the EuControl software. I've tried v3.7 and get a Network configuration error which makes no sense (same configuration as we were using on the hackintosh last week), so I thought maybe I needed v3.6.x and downloaded that, but apparently that's only for PowerPCs. (Which we still have as shelfware, and I even tried mastering on PT 7.4, but that wasn't going to work.)
Any clue as to what's going on here? (I'll post pictures of the error message and our network configuration control panel from my phone in a minute.)
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 05-09-2019, 02:29 PM
Default Re: software problem on Mac OS X.7 (Lion)
Ah. I need to open a facebook account with tapatalk to do that. Not gonna happen right now. The error from EuCon 3.7 is:
Network Configuration Alert
EUCON networks ervices could not be started
There was a problem with the current network configuration that could not be resolved. Please check your network settings and connections and try again. If that doesn't work, lease quit and then restart your computer.
Old 05-09-2019, 02:32 PM
The network control panel is probably not all that useful actually. It's just set to DHCP, as are the Artist controllers (one Mix and one Control) and all are on the same subnet in the building (and all confirmed to be pulling the same IP up to the last digits which are the unique ones to each device on our subnet).
Mountain Lion and Avid Software Avid Technical Alerts 0 07-25-2012 09:38 AM
Lion to SL drive problem colinmansfield macOS 4 03-27-2012 06:46 AM
Upgrade To Lion Get Incompatible Software Message Blank Frank macOS 1 01-20-2012 05:34 PM
Anyone else having a problem with CEDAR DNS One and Lion? jmp Post - Surround - Video 4 10-27-2011 02:43 PM
help with PT software upgrade now my Black Lion 003R mod is here :) JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-16-2010 05:38 AM
