Pro Tools 12 and 11 Crash on El Capitan
Does anyone have PT 12 running on an IMAC w/EL Capitan 10.11.3? Will 12.4 run on Yosemite?
PT12 crashes like crazy. Any command can trigger the freeze. The Imac Screen and control freezes whilst the music plays on. Only way to stop is a pwr button hold reboot. As I continued to hunt for the problem, it got worse. Before it would crash, error message CPU overload/raise edit buffer. This would happen with a couple tracks and plugins. The PT processor monitor said 2% on 4 cores. Bailed on 12 and loaded PT11. Preliminary use (just like 12) has ok results, but Imac meter shows processor using 40-60% (while PT monitor still says 2%) on 16 track session with as many plugins. After a few runs now PT 11 is intermittently freezing too. F3 unlocks it for now. After closing session, Imac won't shut down. Power button hold is only way to shut down. Upgraded Pro Tools from Sweetwater. I have 10, 11,12. Purchased an IMAC Nov 2015. About says Late 2014 3.5 1TB Fusion, upgraded Ram 24g Apollo 8 interface, 2nd display Apple all thunderbolt connected. El Capitan 10.11.3 |
Re: Pro Tools 12 and 11 Crash on El Capitan
The fusion drives are known to be problematic with PT. Are you using an external drive to run your session from?
I'm running 12.4 on El Capitan on a MacPro 5,1 currently and having a few beachballs now and then when running over ~450 voices, but nothing like you're describing.
He used to cut the grass...he was a very nice boy... |
Thanks Clutch. I should probably dump the Imac for a Mac Pro. I'm going to try Studio One 3 first.
System requirements say Mountain Lion 10.8.5
Pro tools 9, El Capitan | Dave Wilson | Pro Tools 9 | 5 | 01-29-2021 02:03 PM |
Pro Tools 10 and El Capitan | johnolly | Pro Tools 10 | 29 | 10-02-2017 12:51 PM |
pro tools m powered 8 El Capitan? | fastsong | Pro Tools 12 | 8 | 04-29-2016 12:02 PM |
Pro Tools HD 12.3 + El Capitan - Has anyone taken the plunge yet? | janmuths | Pro Tools 12 | 47 | 11-27-2015 04:21 AM |
Crash Crash Crash Live 6 Pro Tools Rewire | TimmyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2007 11:26 AM |
