Old 06-22-2016, 08:47 AM
MattheWood MattheWood is offline
Default MIDI interface control of Digidesign PRE
Hi there,
Is there a way to control the input gain function of the Digidesign Mic PRE with an external trim pot ? Also, can that control be ganged across several inputs at once? I wanted to use something simple like the Presonus Faderport, but I didn't know if the HUI protocol accessed these parameters.
Anyone done something like this?
Thank you!
Matthew Wood
Old 06-22-2016, 09:08 AM
Top Jimmy's Avatar
HUI will not, but I believe midi cc on the correct channels will. The Focusrite Rednet preamps use the same cc as the Pre. You can download the Rednet pre manual and there's a table showing the midi cc channels for each parameter on the pre. Program the appropriate cc channels to linear or rotary encoders on a midi controller and route the controller to the pre and you should have gain control.
James Cadwallader
Old 06-22-2016, 09:42 AM
Default Re: MIDI interface control of Digidesign PRE
Thank you. Just so I am clear, would I be bypassing the PRE's gain fader in Protools to just use an external rotary encoder directly with the PRE, or could I somehow merge these controls so they both work simultaneously?
Thank you so much for you time.
MW
Old 06-22-2016, 09:47 AM
MW
If your "rotary encoder" can send MIDI CC commands.
You can't "merge" anything, each separate controller is unaware what MIDI commands (absolute gain settings) the other is sending the pre.
Old 06-22-2016, 09:50 AM
So something like the Korg nanoKONTROL2 could be assigned the MIDI CC commands for channel and input gain on the PRE, and this would be the master controller of those parameters. The Pro Tools internal PRE software peripheral interface would be bypassed with this setup? Thank you!
Old 06-22-2016, 11:24 AM
YYR123's Avatar
YYR123 YYR123 is offline
It should reflect on the screen, the changes you made on the 3rd party hardware, but....
If your asking if it will by pass the controls on the actual box it self....I believe that is a no. Not sure but I can't see midi cc defeating the actual hardware controls on the Pre.
If you are asking if it will show the software readout in ProTools? You would have to have midi going both ways for it to actually show the readings and or "be active" and allow you to change the Pre's gain via The pro tools application.
If that makes sense, thus the connections for midi in and another one for midi out
Daniel
Old 06-22-2016, 02:46 PM
Top Jimmy's Avatar
The trick here will be getting the nanokontrol to speak directly to/from the pre without having to loop through Pro Tools. I'm guessing this can be routed in audiomidi setup. Otherwise it might require a controller with real midi ports.
James Cadwallader
Digidesign MIDI interface 685 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2006 01:06 PM
midi interface and HD non digidesign fasttraxx Tips & Tricks 0 09-08-2004 03:41 PM
Digidesign MIDI Interface ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-06-2004 04:41 PM
Digidesign MIDI interface` hiltonius Pro Tools TDM Systems (Mac) 1 08-11-2002 05:54 PM
Digidesign MIDI Interface Baba Omar Jun Pro Tools TDM Systems (Mac) 1 05-26-2000 07:09 AM
