Old 03-29-2016, 02:53 PM
priorytools priorytools is offline
Default This is driving me nuts (first chord isn't selected)
So if I have some quantised chords. Let's say 4. 1 bar each.
I have 4 bars I want to repeat. In clips or blocks view, if I select that 4 bars section in order to copy paste or repeat, the first chord isn't selected.
Face palm… wtf ?!
Also, in block or clip view, we can't cut / separate notes …? Really?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 06-03-2016, 09:50 AM
TheMightyQuinn TheMightyQuinn is offline
Default Re: This is driving me nuts
Are you sure you're capturing (selecting) all of your desired notes when performing your desired selection copy? It can look like that is so sometimes, but depending on where your notes have landed, you might actually have notes starting before the actual bar and/or beat point resides. It's the start point of a note that defines where the note is on the timeline, not where the sustain or body of the note resides.
If your midi note(s) start even ever so slightly in the bar preceding your selection (assuming grid mode here), you'll find that your paste will not include what might think you have actually copied. You must select both the starting points of all desired notes as well as their ending points.
If that is the case, you need to expand your copy section to include the bar (or some portion of) before your desired bar and notes or get out of grid mode while make your selection.
Alternatively, while in Slip Mode you could try nudging the offending 'missing notes' back in time a bit manually so that they start within whatever bar you are trying to copy. Then try your copy and paste to see if all is as desired.
Sorry, can't help with the block or clip mode questions as I never work in either of those views working when with MIDI.
Hope this helps some...
Old 06-03-2016, 10:31 AM
DonaldM's Avatar
DonaldM DonaldM is offline
2 thoughts. Go into note view and make sure all the notes of the first chord actually begin on the first beat, and not any point before. One way to fix that is just quantize. If you have 4 chords, 1 4beat measure each, then just quantize to whole note and all should be well.
You can also just use the trimmer tool to trim any notes starting before the first beat.
That's most likely what's causing your issue.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Driving Me Nuts Cal D Windows 9 06-28-2015 07:39 PM
This is driving me nuts Cal D Pro Tools M-Powered (Win) 2 09-07-2009 05:50 PM
S/PDIF driving me NUTS!!! TommyComa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-22-2007 02:10 PM
PT Driving me nuts!!! mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-10-2005 01:03 PM
driving me nuts stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2003 06:03 AM
