Old 12-04-2015, 12:27 AM
muesli muesli is offline
Default Re: 12.3.1 midi bug??
Originally Posted by Ianduarte View Post
I have been having a problem with the midi instruments where the Sustain pedal works normally while you play, but everytime you try to record using it, it stops responding as if it wasn't pressed. Once again, this problem doesn't happen when you are not recording.
Anyone else noticed that behavior?
i have the same issues with the sustain pedal...must be a bug
MacPro 12-Core, 48 GB RAM, OS 10.12.6, PT Ultimate 2019.12.0 HDX, Antelope Orion32HD III
http://17-studios.com
Old 03-18-2016, 06:55 AM
Bennett Paster Bennett Paster is offline
Default Re: Problem with MIDI Merge on - sustain events
PT 12.4, 2016 and this MIDI merge problem still persists. Glad I found the answer here, but it's still frustrating. Avid- please address this issue. Thanks.
Late 2013 Mac Pro (trashcan), 2.7 GHz 12-Core Intel Xeon E5, 64 GB 1866 MHz DDR3 ECC, AMD FirePro D300 2048 MB, Startup disk SSD 512. OSX 10.15.7, Pro Tools 2022.10. Carbon (AVB), Lynx Aurora 16(n) (Thunderbolt)
Old 03-18-2016, 07:09 AM
ChrisSimon ChrisSimon is offline
+1
Chris Simon
www.TwinMusic.de
Old 10-18-2017, 02:57 PM
jeffro's Avatar
jeffro jeffro is offline
We have fixed the underlying issue and added automation-style modes (right+click to select) in Pro Tools 12.8.2. Check out the video.
linkedin
Help midi sustain problem weezamiah MIDI 3 05-21-2014 03:21 PM
MIDI Sustain Problem In Playback digijohn macOS 2 06-11-2013 06:27 AM
MIDI sustain problem djcream 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-30-2011 10:09 AM
Problem Recording MIDI events w/ Reason Rewired singerfc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-18-2010 05:58 PM
MIDI Merge Problem sdre909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-16-2010 03:41 PM
