Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 07-09-2009, 02:37 AM
woodpigeonblue woodpigeonblue is offline
Default New Firewire External HD
For several months I used my system drive for recording to. I know this is not recommended but I did and luckily I didnt have too many issues. Recently I purchased a new OWC Firewire 400 external HD. I formatted it for Windows and it all seemed fine and easy. I copied 50G worth of pro tools files across to my new external audio drive. I know I will have to change PT prefs so it writes to the new volume but I used it for recording yet.
My first question is: has anyone else done something similar like this before and come across any problems? eg i copied over a folder which holds all my session data for several tunes but is thre any other folders that i will need to bring across such as 'digidesign databases'?
Secondly, when I try to 'safely remove hardware' from the system tray it tells me the generic volume is busy. This happens when I have all programmes closed and have finished writing or accessing the audio drive. This is probably a Windows problem but if anyone has come across this and found a solution then it would be handy. I use xp SP2 and have the external connected by FW400.
Thanks in advance for any responces..
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
Firewire Solo and Firewire External Drive TrevorForrest Pro Tools M-Powered (Win) 6 04-28-2006 02:59 PM
External HD: FireWire 400 or 800 rkranendonk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-13-2006 07:27 AM
Help With External Firewire HD _mat_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-02-2006 02:14 PM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
