Old 09-17-2010, 09:57 AM
MickeyManders MickeyManders is offline
Default Eleven Rack and other DAW
Ha folks !
I've got a question ! I've recently bought the AVID Eleven Rack and i would like to use it with Ableton Live 8, but when I select the 11R in a track to record I can only hear the Dry sound ?! is it even possible to use the 11R with other DAW ?
Thanx a million
Old 09-17-2010, 10:37 AM
madgt621 madgt621 is offline
Location: Current: Ikebukuro, Tokyo, Hails from: San Francisco
Default Re: Eleven Rack and other DAW
It is possible, but it's a little sketchy and of course you don't have any of the embed features. Also, with other DAW's, Ableton and Logic specifically, i can't get the 11R out of "standalone" mode. So as i play through it, i hear double of what i am playing. Playback is all good though.
But to get the wet signal into Ableton, you need to go to "preferences" and select the Eleven Rack as your input device. Then go to "Input Config" and enable the inputs 1~8. Afterwards, in the track, select 3/4 (if stereo), or 3 or 4 (if mono) and that should give you the wet signal.
Hope this helps!
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 09-17-2010, 11:26 AM
hoss33 hoss33 is offline
Same with Cubase
Old 09-17-2010, 11:34 AM
Maybe it could be added in a firmware update? the ability to mute or take it out of standalone mode without PT, so it can function as an interface only. It super annoying cause the only fix right now is to mute the input monitor, but then the 11R is functioning outside of the mix. and more often than not, it leaves me with a ridiculously loud guitar over a normal sounding click or track. it really kills the feel.
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 01-19-2011, 11:55 PM
Gunnar333 Gunnar333 is offline
I made a little tool to use the eleven rack with cubase as a midi device.
I could only test it with my DAW (Cubase 5 - 64bit, Win7) but it should work on other Cubase Systems, too.
It would be nice to get any feedback on it.
https://sites.google.com/site/elevenrackmididevice/
Old 01-20-2011, 12:17 AM
Gunnar, this is the coolest thing!
Old 01-20-2011, 01:32 AM
jimification jimification is offline
Hi Mickey, I'm using the Eleven with Ableton Live 8 and it works great. Let me know if it's still not working right and maybe I can help you with settings etc.
Old 01-20-2011, 04:06 AM
well i'm not Mickey, but I would love to know your method of running the 11R with Live 8.
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 01-20-2011, 04:50 AM
bredo bredo is offline
When used as your main audio interface it's no different to set up than in Pro Tools.
One track set to guitar input - ReAmp output.
Next track set to Eleven Rig input - Mainout/groups or whatever output you please.
The only difference is that you can't use the Editor window.
Old 01-20-2011, 05:04 AM
That and the whole doubling guitar problem.
which I'm not aware of an actual fix for. My work around is to use the 11R as a standalone, into another interface via 3 cable method.
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven Plugin as Eleven Rack replacement pureanalog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2010 01:57 AM
