Old 04-04-2013, 11:54 AM
ianbee ianbee is offline
Default Upgrading RAM on iMac
I just got an imac with 8gb of ram and am going to order more ram for it. I'd like to save a bit of money and just order 16gb of ram (instead of 32gb) and add the ram in the slots giving me a total of 24gb of ram. Is this even possible though? Can custom ram work with mac ram? What do you suggest?
Old 04-04-2013, 02:28 PM
Craig F Craig F is offline
Default Re: Upgrading RAM on iMac
depends on the iMac, some of the new ones are not upgradable
(Apple has so turned into Big Brother)
if you have a iMac that the RAM is not soldered in then you can add RAM
I would recommend only getting quality RAM (should have a lifetime warranty)
I like Crucial myself http://www.crucial.com/?gclid=CI-MkZ...130404212729:s
check at OWC they know what can go into what
Thank you,
Craig
Old 04-04-2013, 02:44 PM
boxedin boxedin is offline
You've got to check your manual to see what you can upgrade to. I have a 2012 iMac, 3.1GHZ Intel Core i5 and the maximum I could install was 16GB. Look on YouTube for videos on how to do it. It was very easy.
Old 04-04-2013, 11:08 PM
rogerhavoc rogerhavoc is offline
Totally possible. I just got a 27-inch, Late 2012 iMac and I ordered it with 8 GB of ram. Went to FRYS the same day and got 32 GB 1600 MHz DDR3 of ram. Super easy to install!
Good luck,
Roger
www.whitenoiselab.com
MacPro 3.5 GHz 6-Core Intel Xeon E5 - Pro Tools Ultimate + HD Native + HD OMNI
MacBook Pro 2.9 GHz i7 16GB Ram (Retina, 15-inch, 2016) - Pro Tools Ultimate + Apollo Twin
iMac 27" 3.4 GHz i7 32GB Ram (Late 2012) - Pro Tools Ultimate + Mbox Pro (3rd gen)
Old 04-05-2013, 04:51 AM
Good luck,
Roger
I think the 27" is the only one with easily user upgradeable ram via the door in the bottom of the unit just like the older iMacs. The ram in the 21.5" is soldered in.
Jack
QAPLA!
Old 04-05-2013, 09:55 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Correct, and it's only the very latest generation of "thin" 21.5" imacs that have the soldered RAM. Earlier versions of the intel-base imac just need a small phillips screwdriver to access the RAM.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 04-05-2013, 02:33 PM
Yep. Apple messed up big time with the 21.5" iMac this time around. Glad I got my refurb 27"
Jack
QAPLA!
Old 04-05-2013, 06:58 PM
sdelsolray sdelsolray is offline
+1 and accurate. My 21.5" i5 iMac (late 2011) has upgradable RAM.
Upgrading to New iMac 60Strat Eleven Rack 3 12-22-2011 10:18 PM
Upgrading from PC to iMac fevoice General Discussion 5 03-26-2011 10:32 AM
Upgrading to PT8 on a new iMac beatbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-08-2009 03:02 PM
Thinking of upgrading G5 to new iMac. What PT version? Charlie_OZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-10-2007 06:06 PM
upgrading my imac G5, suggestions.... samuelowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-08-2005 02:49 PM
