Old 02-17-2011, 10:53 AM
NoiseRoom's Avatar
NoiseRoom NoiseRoom is offline
Default 11R not showing up under Hardware Setup
Hello all,
I received my 11R yesterday and love the sounds I've been getting from it.
I was able to install the drivers, upgrade the firmware and edit the parameters from within PT9. I connected the 11R to my 003R with two S/PDIF cables along with the 11R to my Mac Pro with the USB cable.
Under the System Preferences I have the 11R set to S/PDIF as the Digital Input/Clock Source.
I'm able to record from the 11R using S/PDIF as the I/O with no problems however under the "Hardware Setup" only the 003 shows as a peripheral and the SYNC S/PDIF light is NOT on. The 11R does show as a playback Engine though.
I'm thinking that I need to add the 11R as a peripheral but don't see instructions on how to do that.
Any thoughts on getting this to sync properly?
Thanks,
Steve
PT9 9.0.1 on Mac Pro 10.6.6
Axiom Pro 61
Digi 003R
Eleven Rack
Noise Room
Old 02-17-2011, 12:49 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: 11R not showing up under Hardware Setup
the sync light does not come ON, on the 003 when the 003 is the main interface. Do a test. Set the 11R to Internal and the 003 to SPDIF, then the sync light will come on.
The 11R will not be a playback engine because you can only have 1 playback engine at one time, which is the 003. Here are some tutorials about using the 003 and 11R together:
Eleven Rack Tutorial - Hook Up To Another Interface With S/PDIF
and instructions to Re-Amp when using another interface (not the 11r) as your Main Interface
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 1
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 2
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 3
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-17-2011, 12:56 PM
NoiseRoom's Avatar
Thanks you for responding to my post.
Yes, the SYNC light did come on when I set the 11R to Internal and the 003 to SPDIF.
My biggest concern/question is not seeing both the 003R and the 11R in the Hardware Setup Peripheral window as it does on your videos.
I was under the impression that I would see both in there.
BTW, thanks for your videos :)
Steve
Noise Room
Old 02-17-2011, 01:15 PM
NoiseRoom's Avatar
Actually, after reading some other posts, I understand it better now. I guess with PT9, it won't show up in the Hardware Setup Peripheral window as it does on your videos. Instead, it will show in the System Preferences and that's where to make the adjustments.
On another note, since I already have PT9, is there anything that can be done with the version of PT that comes with the 11R?
Thanks again!
Noise Room
Old 05-29-2011, 01:12 PM
ac30fan's Avatar
ac30fan ac30fan is offline
I don't see 11RACK in Hardware Setup or in System Preferences.
Im on PT 8.05 with current drivers and Rack Firmware
Thanks!
Old 05-29-2011, 03:43 PM
ac30fan's Avatar
Thumbs up Re: 11R not showing up under Hardware Setup
Thanks!
Disregard post. All better now
2019 iMac 27" 5k Retina
3.6 Ghz 8-Core Intel Core i9
Mac OS 10.15.7 / 60GB RAM
UAD FW Apollo Duo (Thunderbolt Card)
PT 2021.3
Eleven Rack FW v2.00.1 / Software 1.2.14
Digi 002 Pro Tools 10 hardware setup not showing. JPS90 macOS 1 10-25-2014 02:04 PM
MTP AV not showing up in my Audio Midi Setup siuberto Socarras 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-17-2013 08:56 AM
Motu Traveler not showing in PT setup>hardware Kraayus Windows 1 09-12-2012 07:14 PM
"adat" option not showing in clock source: hardware setup! Pran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2007 03:35 PM
002 Not showing up in midi setup. Please help toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-17-2005 03:39 PM
