96 KHz Sample Rate ... How ???
Hi There ...
I'd like to record my projects using 96Khz Sample Rate, but my system just doesn't seem to cope with that . I'd like to use AmpliTube Fender SE for guitar tracks (AUX-Busses) SSD LE for drums and a few other VST / RTAS FX + instruments . Now ... I really think my PC (Windows 7 / tweaked for DAW-use) should be able to handle all the stuff I feed it with . But is 96KHz sample rate all but a dream. My Setup : Intel P4 Dual Core (2 x 3GHz) ASUS P5Q 4 GB (Fast DDR) Separate System and Audio HDDs (UDMA-6) Dual Monitor Graphics Controller (NVIDIA GForce 9600 Integrated) Now ... please share your knowledge . Regards, toni S |
Re: 96 KHz Sample Rate ... How ???
While there are clues here about your system a Sandra report would say so much more. Most of us will be waiting for that.
http://duc.digidesign.com/showthread.php?t=193635
What interface are you using? Does it support 96?
That's a lot of resources devoted to an inaudible octave. I'd rather improve the capturing and processing of frequency ranges people can actually hear.
"AD converter designers can not generate 20 bits at MHz speeds, yet they often utilize a circuit yielding a few bits at MHz speeds as a step towards making many bits at lower speeds. The compromise between speed and accuracy is a permanent engineering and scientific reality. The optimal sample rate should be largely based on the required signal bandwidth. Audio industry salesman have been promoting faster than optimal rates. The promotion of such ideas is based on the fallacy that faster rates yield more accuracy and/or more detail. Whether motivated by profit or ignorance, the promoters, leading the industry in the wrong direction, are stating the opposite of what is true." - Dan Lavry - http://www.lavryengineering.com/docu...ing_Theory.pdf Note that you're still better off with converters that are *capable* of higher sample rates, but only because they have more resources to convert to proper sample rates better. Nyquist was right. |
Every record we have sold except one has been recorded at 44.1 or 48 / 24bit, but don't tell anyone.
Another thing:the big studios are still using tape or just hard disk and if so, has is it been recorded at 96 khz? |
I allways record at 24bit/96Khz. I have the CPU Power, I have the Hard Drive Space so I see no reason to not record at 24bit/96Khz. Now you do have to know what you are doing and have track/channel management or you could start to have problems. If you are using a Firewire External drive after so many tracks the system really works to pull the wav files into PT.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
I went to a top of the line studio running all the 192 I/Os but for some reason they only recorded at 48. WTF.
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Bit Rate / Sample rate | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2010 08:55 PM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
Bit rate & Sample Rate | WizDoomBorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-02-2002 12:54 AM |
