Hardware not showing on PT boot
I'm having a problem when I boot Protools after starting up the computer where Protools gives the message that "hardware is not connected or is in use by another program"
(neither of which is true). I can fix it by trashing the "digisetup" preference. Then everything is fine. I can quit PT and then reboot PT and everythings cool but as soon as I shut down the computer and restart , no hardware shows up. Don't think I changed anything software or hardware wise. Setup Mac G4 733,OS9.2, Protools 5.1.1 , 888/24, Adat Bridge . Any ideas? Thanks! |
Re: Hardware not showing on PT boot
Do you have the Dididesign control panel installed? If so, you may need to open the Sound control panel and set the sound output to "built-in".
11R not showing up under Hardware Setup | NoiseRoom | Eleven Rack | 5 | 05-29-2011 03:43 PM |
-1133 hardware in use on boot up | gonzolagonda | Pro Tools TDM Systems (Mac) | 9 | 01-22-2009 11:55 AM |
mbox 2 pro box hardware not showing | lechszcz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-28-2008 03:26 AM |
Initializing Hardware (DSI) ....Won't BOOT!! | dversion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-11-2005 02:36 PM |
Digi 002 hardware will not boot !!! | autotune77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-16-2004 07:36 PM |
