My big problem, please HELP
while hearing a single track[(audio or midi) anytime when i loop a section for example] in pro tools, everytime i try to play along with it or change(automate) the sound that playing (with anyone of my midi consoles) the software "stuck" and not responding , the midi console that sent the midi track stuck too and the firewire gets a signal that wont stop until shutdown....
at first i thought it was one of my consoles but after shuting them down one after another, my problem still remains... please help me! I have Pc pentium 4 Intel motherboard , cpu 3 Ghz , Ram 0.99 running Pro tools m-powered 7.1 with M-audio firewire 1814 consoles: Access virus Ti , Clavia nord rack 2 , Alesis micron(control keyboard) , Roland mc909 connected by M-audio midisport 4X4 (usb) I dont know what else to do, the only way it didnt crash, is when i shut the Midi thru optionon the software down, but then i cant control any of my synths.... Thank you very much Lee |
Re: My big problem, please HELP
Do you have any "dangling notes" that sit across your region boundaries (or more specifically, your loop boundaries)?
This is a notorious problem with ProTools, and yes, the "midi thru" should absolutely be turned off anytime you're doing recording. Strictly speaking, the "midi thru" is only needed to monitor virtual instruments. (If you need to be listening to "some other midi" while you're looping, you can always print it first, and use the printed track during recording, then throw it away when you're done). The other thing though, is that your loop boundaries might be sitting right in the middle of a midi note. One thing you might try, is extending your loop range a little beyond what you actually want to record, on each side (ie a little in front, and a little in back). If there are any dangling midi notes there, you'll see them. |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem | tylerparkinson | Pro Tools M-Powered (Mac) | 0 | 08-21-2009 02:20 PM |
digi 002/7.4 installation problem/not recordable volume problem | fifthflaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2008 01:28 PM |
Audio Regions Display Problem & Grabber Problem | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2002 04:08 AM |
