Double Compression
Just wondering if anyone remembers or has heard of double compression. I believe it requires two channels (one highly compressed) then the output is fed into a copy of the original signal and compressed again. Is that it or is there one more step that I am talking about?
Thanks Zach |
Re: Double Compression
Aaron Mulqueen - 001 HD Native |
I've been known to use Smack's "Tape" setting as the first plug, then EQ, then another compressor on guitars and vocals. The Tape setting seems to slow down the transients and warm up the sound a little with out sounding really compressed. Then I like to EQ before a heavier compressor to keep unwanted frequencies from triggering the compressor. However I'm not an engineer and just going with what I like. As far as the two track method, I've heard of drum sub mixes being compressed hard with an aux send and then blending it with the regular mix. But I've never done it. I read about it in some magazine that was doing an article on how to achieve a sound like John Bohnam's drum sound. They also used the compressed mix for verb and maybe delay. But I was just reading this in a store and didn't bother to purchase the magazine.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
CME
Ummm... I did like the chapter on "Cracking Compressors" from Michael Stavrou's book Mixing with your mind very insightful. filosofem
double notes | john1192 | MIDI | 0 | 04-17-2007 08:03 AM |
S-MUX / Double Speed / Double wire | jiggy_bau | Pro Tools TDM Systems (Mac) | 3 | 06-27-2005 09:36 AM |
Double Compression: | Jake001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-16-2002 08:38 AM |
i'm i seeing double? | surgestrip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-10-2001 08:36 PM |
double,twice,again | Azael | MIDI | 5 | 02-10-2001 08:33 AM |
