Old 03-18-2021, 08:25 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: 2018.7 Automation choppy with Eucon controller
Originally Posted by EddieJones View Post
This should be much improved if on the latest versions of PT and EUCON
Thanks Eddie.
Unfortunately we cannot update beyond PT 2019.6 due to bugs. Does the latest eucon work with 2019.6? I know it's not supported, but usually that just means it hasn't been tested but might work jut fine. I'm not sure if there is anything I am missing.
Also I don't understand where this is coming from? It seems to only affect a small group of people. Can you give some insights?
Old 03-18-2021, 09:06 AM
EddieJones's Avatar
Yes the latest EUCON should still work with PT19. Its easy to try, and if not happy re-run the installer and select remove all apps and Prefs and go back to the older version. I do remember though that some of this fix was in PT though.
Eucon 2018.3 new eq3 layout? espron Avid S4/S6 10 04-20-2018 11:44 AM
Cannot find 2018.3 eucon installer Joris de Man Avid S1, S3, Dock and Control App 6 03-29-2018 11:18 AM
EUCON 2018.3 Now Available—What’s New editorbelga General 0 03-26-2018 03:06 PM
Pro Tools 2018.1: Error in Controller-Personality "EUCON" ... johab Pro Tools 2018 0 03-02-2018 01:40 PM
Choppy Automation Problem kmackinley Windows 1 01-28-2013 02:00 PM
