Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 07-19-2017, 01:23 AM
Du0 Du0 is offline
Default Monthly license renewal doesn't work properly WIN10 PT 12
So since I subscribed to Pro Tools back in February I have had an issue every month a few days from my monthly renewal date of the 21st. On or about the 18/19th of every month I cannot use pro tools due to my licences going into pending renewal mode. I have a support case open with Avid since 3/20/2017 but after now 35 and counting discussions with them they seem unable to provide a solution or even a valid reason why I can't use the software I'm paying for.
By the way Avid 2 days or more to respond to a reply on an open case just doesn't cut it sorry.
So I'm posting on here in the hope that anyone else has had the same issue with the subscription system and managed a fix. Although I'm 99% sure by now it is an issue with Avid's billing system.
Cheers for any advice!
___________________________
ASUS P8Z77-V, i7-3770K CPU @ 3.50GHz, 16GB DDR3, Win10Pro 64bit, NVIDIA GeForce GTX 650, PT 12.8.0
Old 07-20-2017, 12:49 AM
DigiTechSupt's Avatar
Default Re: Monthly licence renewal doesn't work properly WIN10 PT 12
Hi Du0,
Sorry about this. Support case started. Please check your Email. We'll be investigating your account and have someone contact you later today.
Best regards,
Tope
Avid Audio Tech Support
Support FAQ
Old 07-20-2017, 12:55 AM
Du0 Du0 is offline
Hi Tope,
Thanks for the response.
As an update today I logged off my user account on my PC and logged back in. I also deactivated my license in iLok manager and then reactivated it and pro tools opened. The licenses are still in pending mode however which I think is the trigger every month for the issue.
Cheers!
C 24 doesn't work properly with HEAT Blues Bird Pro Tools 12 5 07-29-2015 09:24 PM
session doesn't work properly! kppoykko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-31-2007 10:18 AM
reinstall doesn't work properly redwine5 Digidesign Hardware & Software 1 01-10-2007 03:09 PM
Bounced .wav file doesn't work properly Digger Dan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-10-2006 03:43 AM
