Old 03-31-2011, 10:43 AM
Epik Productions Epik Productions is offline
Default SYNC HD Not Working
Hey,
Today for no reason, our SYNC HD will not lock to sync in the active session.
We are tracking at 48k 24bit and have 2 192I/O's loop synced to the SYNC HD.
The locked light on both the SYNC HD and in the Session Setup dialog are blinking and will not resolve. It occasionally pulls up a dialog and says the sync is not locked and that audio will still play thou not synced, then it will randomly say its locked. Shortly after this the "locked" lights will begin blinking again. When this is happening, severe jitter is heard across all audio tracks when monitoring.
When the aforementioned dialog box appears the system is not synced and occasionally the sample rate led on the 192 will flash/blink very briefly and faintly. We had this happen during a session and we had to disconnect the SYNC HD from the chain and loop sync the two 192 boxes (with the first in the chain's internal clock set to be the clock source).
Also, when the SYNC HD is powered on, pressing the power button on the unit will not turn it off. We are uncertain if the button is not actually making contact with what it is supposed to or if it is simply malfunctioning.
Any Suggestions as to what this is, or should we be shipping this off to Avid to fix?
Thanks
-Epik
Old 03-31-2011, 01:38 PM
the dude's Avatar
the dude the dude is offline
Default Re: SYNC HD Not Working
I just came across a sync hd with same exact problem
it won't even resolve to it own internal clock as reference
the owner sent to some local repair facility at avid recommendation and of coarse they said it was fixed but it wasn't
there is nothing really to fix inside
so the best solution out of warranty is to ask for an advance replacement and this way they swap it for another unit instead of attempting to fix it
it's a bit costly but so is lossing session time
if it's in warranty still ask for an advance replacement unit it will just cost less
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 02-12-2024, 03:16 PM
Big_Beast_Music Big_Beast_Music is offline
Ok I was having the same problem just now and all I did was change the Mini Digilink cable and it started working again flawlessly
Sync not working Nathan W. Pro Tools TDM Systems (Mac) 1 06-08-2011 03:15 PM
Sync i/o not working actualsizeaudio Pro Tools TDM Systems (Mac) 1 07-22-2005 04:59 PM
Sync I/O Varispeed not working fm_xtk Pro Tools TDM Systems (Mac) 4 02-04-2005 01:32 PM
Is 9 pin working from the Sync I/O? John McDaniel Post - Surround - Video 1 05-28-2002 08:32 AM
Sync I/O not working with Mix Plus! johnnyv Pro Tools TDM Systems (Mac) 8 05-08-2002 09:23 AM
