Old 02-08-2011, 12:45 PM
jeanvaljean jeanvaljean is offline
Default File, New Session, Session Name, Save = Reboot
Pro Tools LE ver 6.1 with a 002; win xp pro 2 gb 1.6mhz cpu:
When I select File, New Session, then Name the session and click on save the pc reboots.
I tried the software on two other pc's using the same 002 and got the same results.
Note pro tools software had to be reinstalled due to a necessary pc restoration. It has worked properly in the past.
Also, have Pro Tools 8.0 upgrade ordered. Is this likely to help this problem? otherwise I'd sure like some help with this.
Valjean
Have session file but no folder to save on dvd??? yachty macOS 3 11-30-2011 07:11 PM
Pro Tools 7 Save Session Copy File compatibility producerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-12-2006 02:56 PM
Handling of removed file with Save Session Copy In el biciclista Pro Tools TDM Systems (Mac) 1 12-21-2005 01:22 PM
WINXP SAVE SESSION COPY IN - PT 5 or 4 File Types grivel Pro Tools TDM Systems (Win) 2 05-24-2004 03:23 PM
File-Save-Session-Copy-In character add DelSpiva Pro Tools TDM Systems (Mac) 1 03-13-2000 08:24 AM
