Elastic Audio Requirements
Can someone please tell me how much computing power is necessary to actually use this without getting the DAE errors? Errors like running out of system resources or buffer size too small, or whatever else even though if you look in the Task Manager you see sufficient resources.
The current "fix" from digi tech support for me was to turn off elastic audio. I'm not posting a Sandra Report because I got this solution from Digi over the phone. PT runs fine except for EA. This is a major feature of PT. I'd like to be able to use it during the editing and mixing process at times without it locking up the application. You can see the system I'm running now in my signature. I'm going to assume it isn't enough. What processor would work? Don't suggest getting a Mac. Or would overclocking work since this processor can OC up to 4 GHz. 3 GHz is pretty safe. 4 GHz gets too hot.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Re: Elastic Audio Requirements
bump for monday
I-tunes audio tech specs requirements | garnoil | General Discussion | 0 | 11-20-2013 04:39 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
Pro Tools LE + M-Audio FT C600, REAL system requirements | Feke | Pro Tools SE and Essential (Win) | 2 | 03-13-2012 06:09 AM |
Live audio: Power requirements calculation: How? | Amnesiac | VENUE Live Sound Systems | 1 | 01-23-2010 04:00 PM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
