Structure Free Browser Hangs
Hey all, I have a problem. Structure Free loads ok, the initial sine wave patch plays, but when I clicked on the browser, I get a spinning ball for over 40 minutes now. The browser has returned the following folders User, User Guide, System and Net. The ball is still spinning ???. I had to shut off my computer to get out of this.
imac 3.06, 4GB Ram , SL 10.6.2, PT 8.0.3, Structure Free 1.1.0, 003 Factory, Glyph HD |
Re: Structure Free Browser Hangs
GPROD do you know if Structure Free has a AIR Data Base File? \Digidesign\DAE\AIR\Content if there is delete it and insert Structure Free again.
filosofem |
That does indicate a file issue.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Also your specs say iMac. The latest iMac's are not officially Qualified.
filosofem |
Filosofem, thanks for all your help. Before I do anything, I just want to be sure since everything else works fine, I have even imported HD sessions that work fine so I want to be real careful......
1. I have a digidesign Data base on my ext. HD It has a unicode folder, in the unicode folder are two files: Volume.ddb and WaveCache.wfm. Are you saying move everything to trash ? 2. DAE, where is it , what is it ? I dont see a folder or file by this name anywhere. |
Nope, none of those GPROD. The directory on PC is System Drive:\Program Files\Common Files\Digidesign\DAE\AIR\Content on Mac I'm unsure but you want the DAE folder that your Plug-Ins folder is kept.
If there is no AIR Data Base File then you should use a workaround like Workspace. And submit a Bug Report. filosofem |
Structure Free Browser locks up in PT10 | cowrange | macOS | 5 | 03-12-2014 07:42 PM |
Navigating to Browser tab in Structure hangs Pro Tools | unifunkd | Virtual Instruments | 54 | 06-06-2011 01:16 AM |
Structure Free Hangs System When Browsing Content | careyletendre | Pro Tools M-Powered (Mac) | 1 | 04-25-2010 10:48 AM |
Structure | Wonder if digi ever tried it's Browser | 25ghosts | Pro Tools TDM Systems (Mac) | 10 | 01-27-2009 10:50 AM |
Structure Free hangs PTLE 7.1 | rlcowa@work2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-18-2008 03:39 PM |
