get louder sound in hd system
hello,i have hd2 system,why mastering in protools not louder than nuendo?
pt with about 120db dynamic range and nuendo with rme 9652 sound card with about 110db? i mix my music in hiest volum with no cliping in protools then increase my master fader until no cliping in c/24 meter and insert it to maxim plugins and get the hiest posible good sound, but it not louder than my past system,why? mix in pt is wery warmer and cleaner and low low distrotion, but it's not louder than my past system.is this any way to get louder sound?
nobody can run pt hd pcie in pc like me!!!hahaha... |
Re: get louder sound in hd system
You could try turning your amp/speakers up
Sorry ..couldn't resist....
Win 7 Pro 64 PT 10 HD, HD4 Accel Jetway JNAF92-Q67 Intel 2700k 3.8ghz 16GB Crucial Ram |
To learn exactly what the difference is:
- Make a 1khz sine wave file (which you can generate in Protools) - Play this same file from both programs (one at a time) at "0" db in the simplest way (no effects, a simple mono audio track directly out to the sound card, etc.) and measure the output at the soundcard with an AC voltmeter. - If there is a difference, you will now know just what it is. There's no guarantee that any manufacturer uses the same output level as "0", although there are some standards (eg, +4dB and -10dB). If you are using something with a gain control (like a headphone out jack), then there is also post-computer analog amplification which you are setting.
steve Your Heaven |
This has to do with differences between the TDM and Native sound processing. You'll have to go deeper into getting familiar how 24-bit fixed and 32-bit floating point processing are different from each other. There is a thread where it's been discussed recently HERE, you might find it very interesting.
thanks,i visit your link and also try it,yes the rtas plugins have louder sound but tdm is very cleaner than rtas.i try to open only one maxim in one mixdown trac,first with tdm and then with rtas (with same seting) and bounced to disk and then listen carfully to each other with my ns10 pro,i think the rtas one have harshnes and master with tdm maxim is very cleaner than rtas.
thank you stsve ,i try it.but wich kind of ac voltmeter must be and wich number must to shw me.
also my proble didnt about line in and out of my hd 192,i only listen to bounced trac that is in my hard vith same program and same seting (volum).one mixed with pt and other with nuendo.
When Louder isn't Better | MikeLip | Pro Tools 9 | 16 | 05-14-2011 10:47 AM |
PT 7 TDM Freeze / Loop / Louder, louder, louder!!! | Floydio | Pro Tools TDM Systems (Mac) | 1 | 03-19-2007 10:22 AM |
Mastering - Trying to make it sound louder | Somebody | General Discussion | 11 | 07-30-2003 02:06 PM |
How can I make my final song sound LOUDER!? | Emo King | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-22-2002 03:19 PM |
Regions sound louder at same level-Is Expansion the key? | Targon | Pro Tools TDM Systems (Mac) | 0 | 09-17-2000 12:30 AM |
