Old 05-14-2007, 03:26 PM
scatta scatta is offline
Default sound cards
i have a pc custom built for music production. do i need a sound card if i have a 002 rack?
Old 05-14-2007, 05:15 PM
sunburst79 sunburst79 is offline
Default Re: sound cards
It depends.
The short answer would be no.
It depends on whether you will be using the computer for anything other than Protools. Protools MUST use the interface to output its audio. You use the 002 to output all of your multimedia and run it through your studio monitors. You will be limited to stereo though.
If you want 5.1 for Multimedia you can install a soundcard and hook a set of 5.1 speakers up to that. But you won't be able to use Protools through the soundcard it will need to output through the 002-So in essence you would need 7 speakers.
I just use my 002. I don't have room for that many speakers
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-15-2007, 01:05 AM
steve at Your Heaven steve at Your Heaven is offline
1 - From now on, use the Windows LE forum (see JUMP button below)- this forum is for different hardware.
2 - Using an 002 with the ASIO driver (and a program that supports it, like Vegas) does let you use more than two speakers, as you can output up to 16 or 18 channels with an 002.
3 - If using Protools software, ONLY the Protools hardware will work.
steve
Your Heaven
Old 05-15-2007, 05:39 AM
I stand corrected. I wasnt aware that the ASIO driver would output more than the two channels in PT. I will have to read the latest version then.
Scott
Core 2 Specs Page
Sound cards gref Pro Tools 10 9 02-24-2013 10:26 PM
SOUND CARDS whitetar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-14-2008 03:34 AM
Two sound cards? deejfro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-11-2004 04:10 PM
Sound Cards Princeton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-01-2002 10:11 AM
sound cards RDOG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-03-2000 09:06 PM
