Old 02-07-2007, 09:51 AM
guitarzzan guitarzzan is offline
Default How big should my audio drive partitions be?
Hi, just getting back into recording again and had a hard drive crash on me. I'm getting a new WD 250G one and am hoping someone here can tell me what the ideal partition size is for PTHD and any other useful info for setting up my audio drive.
Any info would be appreciated...and yes, I did search already. Not much there.
thanks,
Steve
Old 02-07-2007, 12:16 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: How big should my audio drive partitions be?
As long as you defrag when necessary and use an intelligent file system (e.g., NTFS), I'm not sure you need to partition at all anymore.
And of course, always back up on a removable or offsite drive.
steve
Your Heaven
Old 02-15-2007, 10:34 PM
juliussantua juliussantua is offline
If you plan to have a dual partition, I think 40Gb is enough for the System Drive (Boot) and the remaining 210Gb can be used as your Audio Drive. I think Digi recommends to have a separate Audio Drive for Session Files. Hope this helps.
Old 02-17-2007, 01:41 AM
If I remember correctly, partitioning the system drive to use as a system partition and an audio drive is actually WORSE than no partition, since the OS has to access areas on one drive with two sets of protocols. And doing this does not accomplish what is required, giving the audio streaming a separate and unencumbered drive and signal line to avoid interruptions.
steve
Your Heaven
SEAGATE 1TB drive / 10 partitions Tom Pfaeffle Pro Tools TDM Systems (Mac) 34 09-15-2010 07:00 AM
drive partitions woodshopsound Pro Tools TDM Systems (Mac) 2 11-19-2006 07:18 AM
Drive partitions Gordon -10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-03-2005 12:51 PM
how do i tell what partitions belong to what drive maskedman72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-17-2004 07:42 AM
Drive partitions itchyvinyl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-10-2002 11:17 AM
