  #41
Old 03-03-2021, 11:30 AM
Default Re: Pro Tools 2020.12 M1 Mac Mini
Originally Posted by Eric Lambert View Post
Thanks for pointing that out. I've purchased several copies of quite a few of their instruments and didn't know there were updates. Nothing from AIR and I'm on their list.
Check my latest post
  #42
Old 03-03-2021, 02:10 PM
Eric Lambert's Avatar
Oh yes, I'm all too familiar with their support. I had to email them today because of issues getting their former disk authorization system migrated to iLok and I'm nervous about the response.
  #43
Old 03-04-2021, 09:02 AM
Stephen Bond's Avatar
Good news! All these are now showing "Support for Mac OS Catalina and Big Sur"
https://www.airmusictech.com/product...th-500#updates
https://www.airmusictech.com/product/mini-grand#updates
https://www.airmusictech.com/product/hybrid-3#updates
https://www.airmusictech.com/product/velvet-2#updates
I guess the rest will follow along soon?!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #44
Old 03-04-2021, 01:31 PM
seebee62 seebee62 is offline
Another M1 observation. It seems as though AAX plugins play nicer than AU plugins.
Addictive Drums 2 is fine in PT but in Logic Pro it’s a blank GUI although the drums will play. Same with Slate Drums and Slate Trigger in Logic Pro.
Slate is fine PT.
Although EZ Drummer 2 is fine in both PT and Logic Pro.
It’s interesting that it’s Drum plugins that have a AU GUI issue.
  #45
Old 03-04-2021, 03:39 PM
Sardi Sardi is offline
Are you running Logic under Rosetta or natively?
Sounds like it could be a result of running the DAW natively and the plugins under emulation. Obviously with Pro Tools, both are running under emulation.
  #46
Old 03-07-2021, 12:54 PM
I’m running Logic under Rosetta not natively.
  #47
Old 03-08-2021, 04:43 PM
Are you able to run Logic natively if you choose to, or is Rosetta the only option? Being Apple's app, I'd assumed it could go native.
  #48
Old 03-08-2021, 05:01 PM
Yes there is a option to run Logic natively. Funny I’ve haven’t tried it. Things work so well under Rosetta 2 I kinda forgot. It’s a huge difference when it’s was Rosetta 1 from PPC to Intel. At that time I was using Logic 8 I believe. I lose track of DAW’s I’ve used.
Let me see.
Performer Midi only
Performer 6 only 8 Audio voices
Digital Performer
Logic 7,8,9,10
Pro Tools 7 M-Powered
Pro Tools 9,10,12, and whenever Pro Tools went with dates.
  #49
Old 03-11-2021, 12:26 AM
Here’s some PT 2020.12 Session info with the M1 Mini 16/1TB. UA Apollo Twin MKII Big Sur 11.2.3
Fired up this session for the first time on the Mini.
Details
66 Audio Tracks
35 Aux
19 VCA’s
Plugins
Waves Redd17-1
Waves CLA 76-7
PT BF 76 -2
PT EQ3-15
Waves SSL EQ -6
Waves Q10-8
PT D3 Comp-1
Waves SSL E Channel -5
Waves Doubler 4-2
UA SVTC Bass Amp-2
UA 1176-1
Waves SSL Buss Comp-1
PT Trim Plugs-66
Disk Activity 1%
Total CPU Usage 12%
Memory Activity 39%
  #50
Old 03-14-2021, 12:29 PM
For those who may be interested Stylus RMX running great on M1 and PT 2020.12
How to uninstall Pro Tools 2020.11 and revert to 2020.9.1 ArKay99 macOS 10 02-27-2021 02:41 PM
Will Pro Tools 2020 run on Mac Mini 6,2 Sadie Tango Pro Tools 2020 1 10-28-2020 07:59 PM
Pro Tools 2020.5 won't launch on Mac mini mac90501 Pro Tools 2020 27 09-12-2020 08:28 PM
Recommendations for a mini keyboard controller for Pro Tools 2020 christopherc Pro Tools 2020 5 08-15-2020 10:34 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
