PT 4.3
I bought a used PT TDM system. I'm running it on Windows XPWhere can I find a PT 4.3 download on this site?
Dell Studio XPS 9100 12.0 GB RAM 6 processor cores Windows 7 64-bit operating system Display adapter type: ATI Radeon HD 5900 Series Total available graphics memory 4083 MB Dedicated graphics memory 1024 MB Dedicated system memory 0 MB Shared system memory 3059 MB Display adapter driver version 8.791.0.0 Primary monitor resolution 1680x1050 DirectX version DirectX 10 Pro Tools LE 8.0.4cs2 Mbox2 Mini |
Re: PT 4.3
Check the compatibility link. I don't think PT 4.3 will run on any Windows OS (except amybe NT - I didn't even see it in the archive section).
Your system should have come with some install disk, and you will want to upgrade to 6.4.1 (the final upgrade for Mix systems). You may have to call or email Digidesign Support directly if you can't fins a disk and authorization code (usually on the inside of the "Getting Started" booklet).
steve Your Heaven |
