Hi All,
When I do a Bounce To Quicktime Movie, assuming I'm bouncing a QT and not an Avid file, does my Protools spit out the same resolution video I put in? There are no video options on the bounce so I'm assuming the video is not being changed in any way (other than embedding audio). Is this correct? Thanks, Charlie |
Yes. However, from page 1059 of the Pro Tools 8.0 reference guide:
When you have finished your final mix and synchronized your audio events to the movie, you can bounce the main video track (QuickTime or Avid video) and a mono or stereo mixdown of your session to a new QuickTime movie. You can choose from a variety of standard QuickTime codecs, which are fully compatible with other QuickTime applications. How? Hold control-option-command while selecting "Bounce to Quicktime movie..." and you will get a dialog box where you can select different Quicktime options. Cheers, Chris
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 Last edited by ripple FX; 10-20-2009 at 11:49 AM. Reason: additional info |
You're welcome Charlie. AFAIK, PT doesn't do anything to the video. If you simply bounce to Quicktime, a duplicate of the original video is flattened with the audio from the bounce resulting in a new movie with the original codec/size/etc plus a new audio track. The options page takes that one step further by allowing Quicktime to transcode the video to a different format before flattening it with your new audio.
I don't know why it's not mentioned on that page. I learned about it like you just have, by a helpful DUC user ![]() Cheers, Chris
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Why would you bury a feature like that?
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
Uncompressed 10-bit 4:2:2 is an FCP codec. You think an Avid product will bounce to that?
I never understood the hiding of this function either. It should be the window you always get when you choose to Bounce to Movie. I'm very thankful it's there, though. |
I loaded a high res FCP codec 422 at24FPS. when I bounce out are we really sure the Vid file is the same except for new audio?. It seems i would have to assign that in the special bounce option area?
Cheers
Dick Maitland C.A.S. |
![]() Quote:
![]() Great for changing movie files to Photo/JPEG, which according to my post friends has the least CPU hog, if you dont use Canopus etc
Denis Mac Pro 3.3 hexacore 24 gb RAM Lion PT 10 HD Native |
Quicktime Bounce Bug? | sparky3000 | Pro Tools 11 | 1 | 01-13-2014 11:42 PM |
Bounce to QuickTime Different in 9.0.3? | MusoPro | Post - Surround - Video | 2 | 06-03-2011 12:24 PM |
Bounce To Quicktime | ofsaints | Post - Surround - Video | 5 | 10-20-2009 06:29 PM |
Bounce to Quicktime- could not finish bounce ? | gw sound | Pro Tools TDM Systems (Mac) | 5 | 09-09-2007 10:43 PM |
7.3.1 QuickTime bounce - 24 bit not available | jimlongo | Pro Tools TDM Systems (Mac) | 0 | 01-24-2007 01:21 PM |
