Old 12-29-2010, 08:57 PM
FutureBC FutureBC is offline
Default CPU Overload 6101 error
I have a mastering project inside ProTools LE 8.0.4, and all was good as of the last time I saved the project. When I opened it up after a few days of not touching it, I somehow cannot play any part of the session without getting the dreaded CPU Overload error. I'm using T-racks mastering software as a plug-in on all the tracks. It was working fine for weeks, and in fact it is working fine in another mastering project I am working on. So how is it that one works, and the other session gets this overload error? The session with the errors has 10 tracks using the plug-in, and the session that is working fine has 8 tracks using the same plug-ins.
I've tried changing the buffer size to the largest (2048), as well as the cpu usage limit. I've also tried changing the DAE playback buffer settings (currently have it set to level 0 with a large cache size), but that didn't help. Not sure what else to try. Any suggestions on how I can get this resolved?
Here are my specs for the system I'm using:
Macbook Pro w/ Mac OS X Version 10.6.4
2.4GHz Intel Core i5
4 GB Memory
ProTools LE 8.0.4
Old 12-29-2010, 10:45 PM
caruso7r caruso7r is offline
Default Re: CPU Overload 6101 error
Are you reserving any of the processors for other processes in the playback engine?
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 12-30-2010, 09:06 AM
DigiTechSupt's Avatar
I would try trashing preferences and see if that helps.
Avid Audio Tech Support
Support FAQ
CPU OVERLOAD error 6101 HELP hotel17 Getting Started 15 05-14-2016 01:24 PM
error 6101 / 9128 CPU overload MAC PPC G5 johnsongs74 Tips & Tricks 10 04-18-2011 04:03 PM
error -6101 cpu overload peter99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-19-2010 02:28 AM
Error -6101 CPU overload macbookpro Eddiex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-26-2010 02:02 PM
(-6101) CPU Overload Error CujoAC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 07-04-2008 11:20 AM
